Idler Sprockets
Hey guys, we were hoping to use idlers on our drivetrain to give us more clearance while going over the bump.
The problem is we couldn't find any double sprocket idlers on McMaster's website so we had to make use of two single ones. Does anyone know where we can order double sprocket idlers? Thanks - Team 115 |
Re: Idler Sprockets
We've had good success just using rollers. Turn a piece of HDPE or Nylon in a lathe, and put it over a bolt. Not something you'd do in an industrial setting, but usually good enough for a few hours of robot driving... which is all you really need.
Jason |
Re: Idler Sprockets
What do you know. Look what I found tonight: http://andymark.biz/alsp.html.
| Flexible Floating Idler Tensioner | AndyB | Technical Discussion | 23 | 22-07-2008 11:05 |
| sprockets | Adama | Technical Discussion | 12 | 14-01-2007 14:05 |
| sprockets | carbuff | Kit & Additional Hardware | 8 | 12-01-2007 08:30 |
| Sprockets | VinceT | Kit & Additional Hardware | 4 | 18-01-2004 23:07 |
| sprockets | BBFIRSTCHICK | Technical Discussion | 21 | 09-02-2003 01:01 |
