Ball possession
According to the rules only one ball can be possessed and be 3" inside the robot frame.
But, can more then one ball be inside the 3" restriction if still only 1 ball is possessed?, or this is also forbidden? |
Re: Ball possession
POSSESSION: Controlling the position and movement of a BALL. A BALL shall be considered in POSSESSION if, as the ROBOT moves or changes orientation (e.g. backs up or spins in place), the BALL remains in approximately the same position relative to the ROBOT.
i would say that intentionally having a 2nd ball within 3inches of your frame perimeter would be considered possession. like if u have 2, kick the first one then kick the second... u controlled the position of the 2nd one while in possesion of the 1st... incedental contact inside of the frame perimeter should be allowed however. like ur holding one and another rolls into ur frame perimeter... but just like bounces off or moves away when u turn or back up then ur fine. |
Re: Ball possession
BALL POSSESSION is independent of the 3" rule.
Re: Ball possession
I believe Mr. Voshol is correct. If you have like 5 balls under your robot, and all five are only 3" into the robot perimeter, but you are only *controlling* the position of one of those balls, say through a roller or suction, then only one of those balls is in your "possession" and you're 100% legal.
| Hearding VS Possession | Stevenof2619 | Rules/Strategy | 11 | 12-01-2010 22:31 |
| ROBOT BALL POSSESSION | Hito Seika | Rules/Strategy | 2 | 11-01-2010 22:45 |
| WHere do you get Ball Casters/ BAll Transfers for FRC?!?!?!? | leehyungjin4u | General Forum | 3 | 15-01-2008 23:27 |
| Possession of trackball | Nothing551 | Rules/Strategy | 4 | 14-01-2008 23:01 |
| Rule Discussion: Possession | Pavan Dave | Rules/Strategy | 28 | 12-03-2007 16:27 |
