Go to Post To think that one can "learn" engineering in 6 weeks while under the strain of building a robot too is proposterous. FIRST isn't about teaching. It's about inspiring. - Collin Fultz [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 30-01-2010, 11:05
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Slow update speed updating Jaguars
It's taking about 1/2hr to update a jaguar that seems off, any ideas?
Unread 30-01-2010, 17:18
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Re: Slow update speed updating Jaguars
What is your setup? For example, how are you Jaguars connected to the update computer, how are you powering them, etc?
Are you using bdc-comm in the command line or GUI?
List the steps you are taking.
-David
Unread 30-01-2010, 18:31
Kingofl337's Avatar
AKA: Adam
Figured it out, the RJ-12 was crimped upside down. The funny thing is while BDC-Comm was acting odd it looked like it was working. It wasn't until I re-crimped the connector I found out how it should work.
Now I just need to get more then one to work at a time. I've set the black jag to ID 5. Then plugged in a Grey Jag w/100ohm 1% terminator and the second Jag LED won't go solid, and BDC-Comm won't detect it.
The configuration is as shown in MDL-BDC24-GSG.pdf, Page 26, Figure 8-1
Unread 30-01-2010, 19:00
AKA: David Yanoshak
I would double check the cable going between the Black Jaguar and the second Jaguar. If the pins don't go 1 -> 1, 2 -> 2, and so on then you won't get communication.
-David
Unread 31-01-2010, 08:53
Kingofl337's Avatar
AKA: Adam
If I hold the connectors side by side it looks like this.
[FTC]: Slow Down Max Speed!! JohnFogarty FIRST Tech Challenge 10 16-11-2009 13:24
Speed control for Jaguars? BurtGummer Technical Discussion 4 13-02-2009 04:47
Jaguars Slow Yellow Blink - Possible Control System Issue MikeDubreuil FRC Control System 3 26-01-2009 23:04
Could FIRST be updating there website it is running extremely slow. Mr.G Chit-Chat 3 01-01-2005 21:22
How slow is too slow? Joe Ross Rules/Strategy 23 12-10-2004 20:23
