cRIO Timeout
When we run any code on the cRIO it always comes up with a watchdog error. The code still runs but every 1.5 to 2 seconds the light will blink. The drivers station says "Watchdog Expiration: System X, User Y. X and Y both represent numbers.
Anyone know what the problem is? Last edited by kgzak : 30-01-2010 at 18:05. |
Re: cRIO Timeout
The watchdog error is due to a bug when switching between the different tabs on the driver station. You will probably have better luck if you run a search on the error next time before posting. A search for watchdog expiration results in multiple results:
http://www.chiefdelphi.com/forums/sh...g+expirati on |
Re: cRIO Timeout
The watchdog times out even when not switching tabs. Even on the old drivers station we still have issues.
We are using LabView to program and on the new driver station (classmate PC) it says teleop enabled were it should but the light will flash every once in a while. The code still runs. Last edited by kgzak : 30-01-2010 at 18:18. |
Re: cRIO Timeout
Open for ideas on troubleshooting... |
Re: cRIO Timeout
By the way, the Robot Status Light is supposed to blink. When the robot is enabled, it turns off briefly every second and a half.
Re: cRIO Timeout
Ours slows down and blinks twice really fast and then is solid for the second or whatever. When we use the old drivers station for robot mode it says Watchdog. I will look at the it again monday and tell you what I find.
| WatchDog Timeout | popo308 | Programming | 3 | 22-02-2009 22:04 |
| error 5101 : Timeout | Wynlyndd | LabView and Data Acquisition | 3 | 31-01-2006 14:05 |
| Timeout!! | Ricky Q. | Rules/Strategy | 19 | 01-04-2004 22:03 |
| Microsoft Timeout | AJ Quick | Regional Competitions | 12 | 09-03-2003 17:38 |
| Timeout Ruling Discussion | ram | Off-Season Events | 4 | 29-11-2001 13:38 |
