Go to Post Facebook for FIRST already exists. It's called Facebook :) - dcarr [more]
Unread 30-01-2010, 13:14
Sauce Sauce is offline
FRC #1245 (Shazbots)
Sauce is an unknown quantity at this point
Wireless issues
We cannot connect wirelessly to our router from the classmate.
Every other team laptop including mine can reach it with ease, but the classmate can only see the school wireless.
I follwed the documentation on how to set it up I just can't see the network.
Any advice?
Unread 30-01-2010, 13:30
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Wireless issues
You will never need to connect your Classmate wirelessly to the network; it will always go through Ethernet. You won't be able to see it as it is an N network, and from the bit of research I just did, the wireless NIC in the Classmate is a b/g card.
EDIT: I'm wrong. Blackphantom91 is right.
However, I still don't see the need to connect wirelessly. The DS is going to be wired at competition, and the dashboard software changes your Ethernet IP, not your wifi IP.
Aren't signatures a bit outdated?
Unread 30-01-2010, 14:05
Blackphantom91's Avatar
Blackphantom91 Blackphantom91 is offline
Mentor + 4 = Stuck For Life
AKA: Malcolm Stirckland
FRC #1986 (Team Titanium)
Blackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura about
Re: Wireless issues
You can connect your classmate to the router it should work.
[img*]http://i.imgur.com/Os2oTET.jpg[/img*]
Unread 30-01-2010, 15:02
sparrowkc sparrowkc is offline
AKA: Mark
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
Re: Wireless issues
The DS software can handle a wifi connection just like it does an ethernet connection. Look under diagnostics-- one of the indicators is for DS radio. There are instructions for setting it up in one of the control system documents.
You do need a G network. The veteran router can do N and a G at the same time, the rookie router can only do one, and I'm not sure you can make the robot radio connect over G.
Wireless Connection issues techplex Technical Discussion 16 05-04-2010 01:13
Using non KOP router, possible cause of wireless communication issues? saba Programming 10 31-01-2010 13:22
Wireless Thermometer Wireless Data C222 Technical Discussion 9 11-01-2010 08:01
Wireless Issues MacAddict FRC Control System 6 25-01-2009 20:58
Wireless Router Issues zim2411 Scouting 17 09-04-2008 22:24
