Troubleshooting solenoid breakout
Our solenoids aren't activating and we would like some suggestions for troubleshooting the problem. The NI 9472 is in cRio slot 8 and our LabVIEW code is configured for slot 8. The breakout board is wired for 24V from the cRio power connector on the PDB, as shown in the FIRST 24V solenoid wiring diagram, and we're using 24V solenoids. The power indicator LED on the back of the breakout board is lit, but none of the 8 LEDs on the 9472 light when activating solenoids. I measured ~0V across the end of the cable connected to the breakout whether a solenoid was activated or not. We tried moving the 9472 to slot 7 and updating the code, but got the same results. I tried searching CD but didn't see any threads specifically relevant. We would appreciate any troubleshooting advice you may offer. Thanks.
Re: Troubleshooting solenoid breakout
If the 8 status indicators on the cRIO module itself are not lighting up, then the problem is before the Solenoid Breakout.
I assume the Driver Station Diagnostic tab status is all good? The RSL is doing it's long on, short off sequence? Then it's a LabVIEW coding problem. Is the compressor code working? P.S. Good error reporting by-the-way! Last edited by Mark McLeod : 31-01-2010 at 15:48. |
The RSL is not wired up yet, but the LED next to the RSL header on the DSC is blinking. That's on the list of things to do next. The compressor code is working and demonstrated. |
The DS solenoid indicators don't necessarily reflect the solenoids true condition. The RSL just repeats the LED on the Digital Sidecar, so if that's solid for a couple of seconds with a brief off, that means you're enabled and operating correctly.
A real easy baseline code test is to use the "Solenoid with Compressor Example." Set the project IP, run continuously, Enable the Driver station, and just click on the solenoid button on the front panel. It expects slot 8, but you just want to see the status light on the module working. It'll give the NI guys a warm and fuzzy feeling when you talk to them about your problem. Last edited by Mark McLeod : 31-01-2010 at 16:06. |
I know we can get a replacement 9472 from NI - where do we look to find a replacement pneumatics bumper? Last edited by dadamson : 02-02-2010 at 08:52. |
#7
| Solenoid not firing off Solenoid Breakout | spooncwru | Pneumatics | 2 | 30-01-2010 17:46 |
| 5 Amp Fuses for Analog Breakout & Solenoid Breakout | finman | Electrical | 3 | 10-12-2008 11:59 |
| PID Troubleshooting | Disar | Programming | 4 | 13-09-2006 15:27 |
| Troubleshooting - 783 | lee87 | Website Design/Showcase | 2 | 13-02-2005 20:15 |
| Troubleshooting System | SilverStar | Technical Discussion | 0 | 23-01-2004 21:22 |
