Go to Post ...It's two years old, but GP is GP. - Brandon Martus [more]
Unread 31-01-2010, 16:31
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Tilt Sensor
When looking at a sensor such as the following:
http://search.digikey.com/scripts/Dk...&name=Z2009-ND
When it says that it has from an 50-80 degree operating range, what does that mean?
Jacob
Unread 31-01-2010, 16:54
DuaneB's Avatar
DuaneB DuaneB is offline
FRC #1731
DuaneB is an unknown quantity at this point
Re: Tilt Sensor
Looking at the datasheet, it appears that the switch opens once the tilt angle reaches 50-80 degrees from horizontal, then closes again once the tilt angle returns to 25 degrees. However, it's not especially clear.
This part is really a tilt switch (on/off) and not a tilt sensor that measures angle, if that's what you were looking for.
Unread 31-01-2010, 16:55
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Tilt Sensor
From the data sheet:
Operating angle: Tilt of 50 to 80 degrees, when the switch is tilted gradually (approx. 1 degree/s) from the horizontal
Returning angle Tilt: of more than 25 degrees, when the switch is tilted gradually (approx. 1 degree/s) from the horizontal
Just guessing....Looks like it is a switch, the contacts will open when you tilt it at least 50 degrees, but no more than 80 degrees, from horizontal. And they will close again by the time it gets back to having only 25 degrees tilt. This is what happens for slow tilting action, changing one degree per second.
Compass tilt error knine143 Sensors 2 29-05-2008 07:58
tilt/pan away Tangello_angela Programming 4 24-01-2007 16:20
Robots tilt Booger Technical Discussion 19 19-07-2006 10:01
Grabbing Tilt Angle? crossedheart Programming 7 09-02-2006 03:08
Tilt Troubles Mumford 406 Programming 4 29-03-2005 22:19
