cRIO wont run software
alright, so this year our team had to use the cRIO from last years robot. we've written a teleop code (in labview), and seems to have no errors. however, when i go to deploy the code to the cRIO, it says its expecting a nother version of data or something. im guessing it has to do with updating it, but i cant find any tools or patches.
Re: cRIO wont run software
Update your LabVIEW installation, then run the FRC cRIO Imaging Tool to load the v19 image. You will find a pointer to the mandatory update here:
http://www.usfirst.org/frccontrolsystem While you're at it, make sure your Driver Station is updated as well. If your Dashboard doesn't show a directional compass indicator, you'll have to run the updater twice, first uninstalling then reinstalling the files. |
i have run the installer before, it shows that i have the image of FRC_2010_v5.zip
is there anyplace i can just load v19 from? |
If you have v5, the update was not applied successfully.
Follow the links to the LabVIEW update and get a fresh copy of it. Run it to update your development system. Then you'll have the v19 image. |
thank you yet again alan!
| Help computer wont recognize cRio | bio hazard | NI LabVIEW | 3 | 14-02-2009 19:24 |
| DS tty serial and crio run speed | Mr-Shutter | FRC Control System | 5 | 21-01-2009 12:39 |
| cRio losing connection when "run as startup" | mgurgol | Programming | 2 | 12-01-2009 12:18 |
| cRIO wont save program | Arcre | NI LabVIEW | 5 | 07-01-2009 11:45 |
| Will the parallax stamp software run win win2k? | Joe Ross | Programming | 5 | 25-08-2001 13:38 |
