Plugging Solenoid
Where do we wire the solenoid? Thanks for the help.
Re: Plugging Solenoid
cRio solenoid module, slot 7 or 8. If you run out of spaces there, you can use Spike relays.
I encourage you to read the control system manual. Your question is answered there. |
how do i wire the solenoid to the pins
There should be two wires, red and black. Red goes to +, black goes to -. Take the 2-pin cables from the kit (like the 3-pin PWM cables but with only 2 pins) and connect them from the solenoid to the solenoid breakout board on the cRio. Depending on what connectors your solenoid has, you might have to cut the 2-pin cable in half and solder it to the leads of your solenoid.
TY that helped alot we are noob electricians
| Solenoid not firing off Solenoid Breakout | spooncwru | Pneumatics | 2 | 30-01-2010 17:46 |
| single solenoid | seanl | Pneumatics | 4 | 18-02-2007 02:32 |
| Programming a Solenoid | Brigander | Pneumatics | 4 | 17-02-2007 14:06 |
| Solenoid Help | Brigander | Programming | 2 | 14-02-2007 17:13 |
| solenoid/spike | greencactus3 | OCCRA Q&A | 1 | 11-09-2004 09:54 |
