Invariant FPGA Image Version Error?
Hi all,
We have trouble now even establishing connection to the robot and testing code (that we actually confirmed earlier as working). Looking at serial output, it seems that there is an "Invariant FPGA Image Version Error", which we used t o be able to fix (then again, maybe not, but it worked for a while) by compiling the WPILib project in WindRiver along with our program. But now that doesn't work at all. And strangely enough, Watchdog errors from within the cpp file seem to pop up randomly without us even establishing a connection to enable the robot! Observe: Code:
cRIO-907x Boot
Copyright 2007 National Instruments Corp.
Bootrom version: 2.4.7
Creation date: Jul 9 2007, 00:45:07
Press any key to stop auto-boot...
auto-booting...
boot device : tffs=0,0
unit number : 0
processor number : 0
host name : host
file name : /c/ni-rt/system/vxWorks
flags (f) : 0x8
Mounting tffs...
Attaching to TFFS... Datalight Reliance v3.00.1218T
VxWorks Edition for ppc603
Copyright (c) 2003-2007 Datalight, Inc.
done.
3572144
Starting at 0x100000...
ATA device not detected.
Adding 8459 symbols for standalone.
Mounting onboard storage...
Reliance File System Driver
Datalight Reliance v3.2.2 Build 1376BV
Copyright (c) 2003-2008 Datalight, Inc. All Rights Reserved Worldwide.
-> lvusEngine: PPC603 CPU detected...
CPU tick frequency: 33.000674 MHz [Using: 1000 MHz]
MAX system identification name: Team25
Initializing network...
Device 1 - MAC addr: 00:80:2F:11:5A:D1 - 10.0.25.2 /8 (primary - static)
Device 2 - MAC addr: 00:80:2F:11:5A:D2 - 192.168.0.3 /24 (static)
Loading LVRT...
* Loading EarlyStartupLibraries: tsengine
Time sync source: rtc now active
* Loading StartupDlls: debug
Entering debug.o StartupLibraryInit
Debugging is up, target server mounted at /tsfs
VxWorks
Copyright 1984-2006 Wind River Systems, Inc.
CPU: MPC5200 -- Wind River Lite5200 BSP.
Runtime Name: VxWorks
Runtime Version: 6.3
BSP version: 2.0/10
Created: Jul 29 2009, 13:41:47
ED&R Policy Mode: Deployed
WDB Comm Type: WDB_COMM_END
WDB: Ready.
Leaving debug.o StartupLibraryInit
* Loading StartupDlls: NiRioRpc
* Loading StartupDlls: niorbs
* Loading StartupDlls: NiViSrvr
* Loading StartupDlls: nivissvc
task 0xec2ca8 (PAL00f94048) deleted: errno=0 (0) status=0 (0)
NI-RIO Server 3.2 started successfully.
task 0xc3e0f8 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
* Loading StartupDlls: nivision
* Loading StartupDlls: niserial
* Loading StartupDlls: FRC_FPGA
* Loading StartupDlls: FRC_NetworkCommunication
FRC_NetworkCommunication was compiled from SVN revision 2064
Error, Invariant FPGA image version error!
FPGA Hardware GUID: 0x1E53E3F869DC0EE6C45E6FA90AF07C6B
FPGA Software GUID: 0x1E53E3F869DC0EE6C45E6FA90AF07C6B
FPGA Hardware Version: 49391
FPGA Software Version: 49391
FPGA Hardware Revision: 1.0.0
FPGA Software Revision: 1.0.0
FPGA Hardware GUID: 0xAD9A5591CC64E4DF756D77D1B57A549E
FPGA Software GUID: 0xAD9A5591CC64E4DF756D77D1B57A549E
FPGA Hardware Version: 2010
FPGA Software Version: 2010
FPGA Hardware Revision: 1.3.0
FPGA Software Revision: 1.3.0
* Loading StartupDlls: FRC_UserProgram
ERROR: Network communication failed to initialize!
WPILib was compiled from SVN revision 2069
>>>>ERROR: status == -63194 (0xFFFF0926) in Watchdog() in C:/WindRiver/workspace/WPILib/Watchdog.cpp at line 18
>>>>ERROR: status == -63194 (0xFFFF0926) in SetExpiration() in C:/WindRiver/workspace/WPILib/Watchdog.cpp at line 97
>>>>ERROR: status == -63194 (0xFFFF0926) in SetEnabled() in C:/WindRiver/workspace/WPILib/Watchdog.cpp at line 127
Welcome to LabVIEW Real-Time 8.6.1f2
task 0x2199958 (t2) deleted: errno=0 (0) status=0 (0)
NI-VISA Server 4.5 started successfully.
task 0xe412d0 (t1) deleted: errno=1835009 (0x1c0001) status=1 (0x1)
We have all the updates listed on the WPI website under C++ (Workbench Update, reloaded WPILib, Labview Update, DS Update, image v19, all of 'em). Any ideas on this one? Last edited by 1951-44U : 02-02-2010 at 23:28. |
Re: Invariant FPGA Image Version Error?
Wow. This one really stumps me. It reports a version error even though it is clearly able to deploy the image and even print the matching version (the "hardware" GUID, version, and revision). I looked closely at the code that generates this messaage, and it is caused by not being able to open the handle to the FPGA image after it is downloaded. I'll have to get back to you on this one.
-Joe |
Hi,
I'd like you to replace the attached file (unzipped, of course) on your cRIO and reboot your controller, capturing the boot messages just like you did before. It goes in "/ni-rt/system/". I added a few prints that will hopefully point to what is going on. Thanks, -Joe |
Here is what happened:
When we loaded the file in via FTP Client (FileZilla), we rebooted the robot. We intently watched the serial output and found (to our surprise) that everything started up normally! However, upon enabling, a "Watchdog Not Fed" error shows up on the Classmate as a status. So we reloaded our program. But then upon reboot we get the same error as before. Here is the output: Code:
cRIO-907x Boot
A
auto-booting...
unit number : 0
host name : host
flags (f) : 0x8
Mounting tffs...
done.
3554816
Adding 8332 symbols for standalone.
CPU tick frequency: 33.000675 MHz [Using: 1000 MHz]
Initializing network... Static IP address assigned.
Device 1 - MAC address: 00:80:2F:11:5A:D1 - 10.0.25.2 (primary)
Device 2 - MAC address: 00:80:2F:11:5A:D2 - 192.168.0.3 (secondary)
Loading LVRT...
VxWorks
BSP version: 2.0/10
Created: Dec 8 2008, 15:28:17
WDB: Ready.
task 0x132f4d0 (Service Locator Thread 3) deleted: errno=0 (0) status=0 (0)
NI-RIO Server 3.1 started successfully.
task 0x10b7db0 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
task 0x1c54310 (Service Locator Thread 4) deleted: errno=0 (0) status=0 (0)
task 0x1c86ef8 (Service Locator Thread 5) deleted: errno=0 (0) status=0 (0)
task 0x1c2a470 (t2) deleted: errno=0 (0) status=0 (0)
task 0x1ce1668 (ServerAds.Lookup) deleted: errno=13893648 (0xd40010) status=0 (0)
NI-VISA Server 4.4 started successfully.
task 0x1a8e838 (t1) deleted: errno=1835009 (0x1c0001) status=1 (0x1)
task 0x1d01668 (ServerAds.Lookup) deleted: errno=13893648 (0xd40010) status=0 (0)
FRC Control Environment initialized
FRC_NetworkCommunication was compiled from SVN revision 1888
FPGA Hardware GUID: 0x6F0EA7B88ADB8E3FD4127A39E3502C6D
FPGA Software GUID: 0x6F0EA7B88ADB8E3FD4127A39E3502C6D
FPGA Hardware Version: 2009
FPGA Software Version: 2009
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO18writeI2CDataToSendEjPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO26writeI2CConfig_BytesToReadEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter28writeTimerConfig_StallPeriodEjPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E3tAI11writeConfigENS1_7tConfigEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter34writeConfig_UpSource_AnalogTriggerEbPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E9tWatchdog12readImmortalEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO22writeI2CConfig_AddressEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E9tWatchdog14readExpirationEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO22readSlowValue_RelayFwdEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E12tAccumulator13writeDeadbandEiPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter23readTimerOutput_StalledEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol getDynamicControlData.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter11strobeResetEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E9tWatchdog23readStatus_SystemActiveEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounterD1Ev.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E14tAnalogTrigger24writeSourceSelect_FilterEbPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E14tAnalogTrigger25writeSourceSelect_ChannelEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E9tWatchdogC1EPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E7tGlobal11readVersionEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO22writePWMConfig_MinHighEtPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E14tAnalogTrigger15writeLowerLimitEiPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO9readPulseEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO19writePWMPeriodScaleEhhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E14tAnalogTrigger15writeUpperLimitEiPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E14tAnalogTrigger25readSourceSelect_AveragedEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO27writeI2CConfig_BytesToWriteEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E9tWatchdog16readStatus_AliveEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO10writePulseEtPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO18readI2CStatus_DoneEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E3tAI15readAverageBitsEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E14tAnalogTriggerD1Ev.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol setErrorData.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter28writeConfig_UpSource_ChannelEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E9tWatchdog10strobeFeedEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E14tAnalogTrigger26writeSourceSelect_AveragedEbPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E7tGlobal13writeFPGA_LEDEbPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E10tInterrupt32writeConfig_Source_AnalogTriggerEbPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E9tWatchdog10strobeKillEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter36writeConfig_DownSource_AnalogTriggerEbPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E12tAccumulatorC1EhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E10tInterrupt13readTimeStampEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter32writeConfig_PulseLengthThresholdEtPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter30writeConfig_DownSource_ChannelEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO17writeOutputEnableEtPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E12tAccumulator16readOutput_CountEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO22readSlowValue_RelayRevEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter25writeConfig_UpFallingEdgeEbPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E14tAnalogTrigger23readSourceSelect_FilterEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter27writeConfig_DownFallingEdgeEbPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E9tWatchdogD1Ev.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO16writePulseLengthEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO16readOutputEnableEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E3tAI15writeReadSelectENS1_11tReadSelectEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol overrideIOConfig.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO14strobeI2CStartEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO14readLoopTimingEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E10tInterrupt22writeConfig_RisingEdgeEbPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIOC1EhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter15readConfig_ModeEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO7writeDOEtPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E7tGlobal12readFPGA_LEDEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter27writeConfig_UpSource_ModuleEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter17readConfig_EnableEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E10tInterrupt25writeConfig_Source_ModuleEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E3tAI19writeOversampleBitsEhhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounterC1EhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E14tAnalogTrigger20readOutput_OverLimitEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO21writePWMConfig_PeriodEtPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E3tAI18readOversampleBitsEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO6readDIEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E9tWatchdog13writeImmortalEbPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter28writeTimerConfig_AverageSizeEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E12tAccumulator10readOutputEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO13writePWMValueEhhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter16readOutput_ValueEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E3tAI17strobeLatchOutputEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E12tAccumulator11writeCenterEiPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E10tInterruptD1Ev.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E3tAID1Ev.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIOD1Ev.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter18writeConfig_EnableEbPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter26writeConfig_DownRisingEdgeEbPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter32writeTimerConfig_UpdateWhenEmptyEbPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E3tAI14readLoopTimingEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO6readDOEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol FRC_NetworkCommunication_observeUserProgramStarting.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E3tAI19readConfig_ScanSizeEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E14tAnalogTriggerC1EhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter29writeConfig_DownSource_ModuleEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E3tAI16writeAverageBitsEhhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E10tInterrupt23writeConfig_FallingEdgeEbPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E7tGlobal13readLocalTimeEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO25readI2CStatus_TransactionEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E10tInterrupt22writeConfig_WaitForAckEbPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter20readOutput_DirectionEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E9tWatchdog15writeExpirationEjPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E12tAccumulator16readOutput_ValueEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E3tAI10readOutputEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E14tAnalogTrigger24writeSourceSelect_ModuleEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter16writeConfig_ModeEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E7tGlobalD1Ev.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E3tAIC1EhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter24writeConfig_UpRisingEdgeEbPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E7tGlobal12readRevisionEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E7tGlobalC1EPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E3tAI13writeScanListEhhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO19readI2CDataReceivedEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E9tWatchdog9readTimerEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO23writeSlowValue_RelayFwdEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO23writeSlowValue_RelayRevEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E14tAnalogTrigger23readOutput_InHysteresisEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E10tInterrupt26writeConfig_Source_ChannelEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol getCommonControlData.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E10tInterruptC1EhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E4tDIO12readPWMValueEhPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E12tAccumulator11strobeResetEPi.
Warning: module 0x1cff688 (FRC_UserProgram.out) holds reference to undefined symbol _ZN5nFPGA33nAD9A5591CC64E4DF756D77D1B57A549E8tCounter15readTimerOutputEPi.
(unloading partially loaded module FRC_UserProgram.out)
task 0x1ed8608 (FTP Server Connection Thread) deleted: errno=22 (0x16) status=0 (0)
cRIO-907x Boot
W
auto-booting...
unit number : 0
host name : host
flags (f) : 0x8
Mounting tffs...
done.
3572144
CPU tick frequency: 33.000685 MHz [Using: 1000 MHz]
Loading LVRT...
VxWorks
BSP version: 2.0/10
WDB: Ready.
task 0xec2ca8 (PAL00f94060) deleted: errno=0 (0) status=0 (0)
task 0xc3e100 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
FRC_NetworkCommunication was compiled from SVN revision 2123
FPGA Hardware GUID: 0x000000000000000000000000AD9A5591
task 0x2198b30 (t2) deleted: errno=0 (0) status=0 (0)
Default Disabled() method... Overload me!
task 0x21c09d0 (FTP Server Connection Thread) deleted: errno=22 (0x16) status=0 (0)
cRIO-907x Boot
auto-booting...
unit number : 0
host name : host
flags (f) : 0x8
Mounting tffs...
done.
3572144
CPU tick frequency: 33.000667 MHz [Using: 1000 MHz]
Loading LVRT...
VxWorks
BSP version: 2.0/10
WDB: Ready.
task 0xec2d48 (PAL00f94100) deleted: errno=0 (0) status=0 (0)
task 0xc3e198 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
Error, Invariant FPGA image version error! (-63194)
FPGA Hardware GUID: 0x756D77D1B57A549EAD9A5591CC64E4DF
Is the cRIO imaged at v19?
is windriver updated to 4? (http://first.wpi.edu/FRC/frccupdates.html) |
Yes. As the last paragraph of my first post says.
#7
It looks like this might be an issue with the hardware itself. I can see from the boot sequence that you reimaged the cRIO (FPGA Software Version 1.3.0) and the you do have the new OUT file on board (FRC_Communication was compiled from SVN revision 2123) and it's doing it's job (the error isn't being reported anymore) but it's still present. Give NI a call this afternoon and we can go ahead and start the Return Mechandise Action so we can get you a new cRIO as quickly as possible.
#8
Welcome to Chief Delphi, btw.
We have called NI and the problem is going up to the R&D, who are working on it now, waiting for replies on this topic. This topic is my lifeline to NI and to get the robot to work. |
#9
The way the version check works is it simply reads the GUID from the hardware and compares it with the software value... if it fails for the invariant FPGA, it then prints out both versions. The fact that it is wrong one time and right immediately after is troubling. It tends to point to a hardware problem since no other team is seeing this, and you see it consistently. I believe this chassis should be RMA'd. -Joe |
#10
Here are 5 other reboots for ya (i think you may be right):
cRIO-907x Boot
_
auto-booting...
unit number : 0
host name : host
flags (f) : 0x8
Mounting tffs...
done.
3572144
CPU tick frequency: 33.000741 MHz [Using: 1000 MHz]
Loading LVRT...
VxWorks
BSP version: 2.0/10
WDB: Ready.
task 0xec2cd8 (PAL00f94078) deleted: errno=0 (0) status=0 (0)
task 0xc3e130 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
FPGA Hardware GUID: 0x0AF07C6B1E53E3F869DC0EE6C45E6FA9
cRIO-907x Boot
auto-booting...
unit number : 0
host name : host
flags (f) : 0x8
Mounting tffs...
done.
3572144
CPU tick frequency: 33.000718 MHz [Using: 1000 MHz]
Loading LVRT...
VxWorks
BSP version: 2.0/10
WDB: Ready.
task 0xec2d58 (PAL00f940b8) deleted: errno=0 (0) status=0 (0)
task 0xc3e1a8 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
FPGA Hardware GUID: 0x00000000000000000000000000000000
task 0x219ab60 (t2) deleted: errno=0 (0) status=0 (0)
task 0xe41540 (t1) deleted: errno=1835009 (0x1c0001) status=1 (0x1)
cRIO-907x Boot
auto-booting...
unit number : 0
host name : host
flags (f) : 0x8
Mounting tffs...
done.
3572144
CPU tick frequency: 33.000699 MHz [Using: 1000 MHz]
Loading LVRT...
VxWorks
BSP version: 2.0/10
WDB: Ready.
task 0xec2bb8 (PAL00f94038) deleted: errno=0 (0) status=0 (0)
FPGA Hardware GUID: 0xB57A549EAD9A5591CC64E4DF756D77D1
cRIO-907x Boot
auto-booting...
unit number : 0
host name : host
flags (f) : 0x8
Mounting tffs...
done.
3572144
CPU tick frequency: 33.000693 MHz [Using: 1000 MHz]
Loading LVRT...
VxWorks
BSP version: 2.0/10
WDB: Ready.
task 0xec2dd8 (PAL00f94178) deleted: errno=0 (0) status=0 (0)
task 0xc3e230 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
cRIO-907x Boot
auto-booting...
unit number : 0
host name : host
flags (f) : 0x8
Mounting tffs...
done.
3572144
CPU tick frequency: 33.000689 MHz [Using: 1000 MHz]
Loading LVRT...
VxWorks
BSP version: 2.0/10
WDB: Ready.
task 0xec2e48 (PAL00f941e8) deleted: errno=0 (0) status=0 (0)
task 0xc3e298 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
#11
Let's see if my profile changes take effect now...
Sorry but I was the AE that you talked to on the phone just a little bit ago. There isn't any contact information for your Team Advisor so I couldn't call you guys back so I thought I would post back here since I told you to monitor it. I talked with Joe about the issue and we think that it is probably something hardware related because it looks like the FPGA doesn't register properly. It looks like the booting multiple times is also pointing to the same thing. Give us a call and we can pick up the troubleshooting again. Thanks!! |
#12
Just to satisfy my curiosity, what caused those Watchdog.cpp errors in the data I posted in the first post of this topic?
#13
The Watchdog class uses the FPGA chip object interface like all others. One of the first things each class does is check that the FPGA is the right version for the class. If the GUID reads fail, it won't match and will return that same version mismatch error.
#14
Joe-
This is the head coach for 25. I spoke to NI yesterday after Phil was on for quite a while and they want us to return the unit. They were to be sending us a cRIO and we are supposed to return our unit in the box once it arrives. However they had no idea when or if another cRIO would be available any time soon. Time is of the essence here. We cannot afford even a few days lost. Do you have any idea whether units are/will be available in the next day or so? Apparently we cant even buy a new one. WC |
#15
Hi guys -
There has been some confusion on this and so the following will be in the team update going out tomorrow: Teams that need to send their cRIO-FRC back to National Instruments for repair will get a replacement sent overnight to them if it is in NI's system before 4pm Central, otherwise it will be processed and overnighted the next day. NOTE: This is at the mercy of other teams however. We only have so many in stock and if teams that request this do not send theirs back to get repaired in a timely matter, our stock can get low. We are currently fine though. Teams purchasing spare or extra cRIOs will receive their systems in approximately 2 weeks. Let me know if you have any particular questions on here or via email (see below). Thanks! |
| Error "IFI>Master Code Version: 8 " | mecanumbot | Programming | 0 | 24-01-2010 01:30 |
| cRIO Image version? | Chris11246 | Programming | 1 | 14-02-2009 16:44 |
| v11 cRIO Image Error | Team1710 | Programming | 7 | 14-02-2009 12:56 |
| FPGA Image | idahorobot | FRC Control System | 1 | 12-02-2009 01:23 |
| Error in Compiling the Camera Code (B&W Version) | VetteSlick | Programming | 7 | 20-01-2006 20:50 |
