Go to Post Anything that promotes science and technology is okay in my book. - Dan Richardson [more]
Unread 03-02-2010, 00:12
MKenney MKenney is offline
FRC #3070
MKenney is an unknown quantity at this point
Team 3070 Mechanum wheels
So at Team Pronto we just finished fabricating some awesome mechanum wheels. After a week and a half of hard work, we finished attaching the rollers on today. The four wheels are made out of aluminum sheet for the outside plates, ply wood for the middle hub, and delrin plastic milled on lathes for the rollers.
Lots of fun, lots of hassle, lots of time, but in the end well worth it.
Good luck from team 3070!
Unread 03-02-2010, 00:41
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Re: Team 3070 Mechanum wheels
WOW they look great. Probably cost less than buying too...
I would make extras though, one shot with a kicker and that aluminum might bend... how thick is that aluminum?
Cold Fusion's 10th Season
Unread 03-02-2010, 23:47
PaW's Avatar
PaW PaW is offline
AKA: Paul W
FRC #1899 (Saints Robotics)
PaW has a spectacular aura aboutPaW has a spectacular aura about
Nice looking wheels!
We'll see the rest of your 'bot in Seattle.
Unread 03-02-2010, 23:57
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Consider that the similarly designed mecanum wheels available commercially use steel side plates rather than aluminum. I would test their durability extensively now so that you're not scrambling to fix things or make changes at the event.
--Madison--
...down at the Ozdust!
Unread 04-02-2010, 00:00
I have a bad feeling that these wheels may give you more hassle than you have bargained for.
I am not saying this to downplay your efforts by any means, please don't take this the wrong way.
That aluminum looks very thin, too thin for effective use on a mecanum wheel. Second, I am fairly positive that rollers should be tapered from the center of the roller (also I would not recommend delrin as the roller material).
Note that AndyMark mecanum wheels use "convex rubber rollers are sandwiched between 2 steel welded plates" and that is after getting complaints prior to 09 that the wheels were weak and dented easily.
Again, I am just trying to look out for your team. I would really look into purchasing mecanum wheels from AM or seriously rethinking this wheel design.
+.02
Unread 04-02-2010, 00:03
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I'm curious as to your method to bend these. I too share the concern about bending in competition, but for light use it looks great.
Unread 05-02-2010, 11:25
teampronto's Avatar
teampronto teampronto is offline
ʇsı1ɐıɔ&#4
AKA: Ka'i Kau
FRC #3070 (Team Pronto)
teampronto is an unknown quantity at this point
Send a message via AIM to teampronto Send a message via MSN to teampronto
Looking good guys
Team Pronto [3070]: Week 1 teampronto General Forum 5 18-01-2010 20:18
Team Pronto [3070] Promo teampronto Robot Showcase 2 22-10-2009 19:10
Team Pronto (3070) v2 teampronto Website Design/Showcase 12 17-01-2009 23:08
Problem with easy c pro and mechanum wheels pbrules15 Programming 9 03-02-2007 20:38
Mechanum Wheels Andy B Technical Discussion 2 10-01-2006 17:41
