Go to Post As Grandma used to say, "empirical data is better than no data at all." - dlavery [more]
Unread 03-02-2010, 18:18
Jakerman3 Jakerman3 is offline
FRC #3215
Jakerman3 is an unknown quantity at this point
dashboard problem on classmate
Hey, the dashboard randomly stopped appearing above the driver station in the driver account, I ran the update for the dashboard to see if it would fix the problem. After the update it still didn't work, it runs and everything on the developer account and I added the .exe in the startup folder for each user and the folder for all users. It autoruns correctly on the developer side, but still doesn't work for the driver side. Any help would be greatly appreciated
-Jake Aberman
FRC: 3215
Head Programmer
Unread 03-02-2010, 18:22
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: dashboard problem on classmate
There is a selection for Local Dashboard and Remote Dashboard. If it's not in Local Dashboard, it should be.
The Dashboard executable is run by the Driver Station when it is run, not through Startup. It looks in... on the non-classmate DS it looks for C:/Program Files/FRC Dashboard/Dashboard.exe, I would assume the same place on the Classmate.
Kettering Motorsports
Unread 03-02-2010, 18:48
FRC #3215
thanks, i got it working after i exited it and re logged in. I would mail you a cake, but its a lie...
Unread 03-02-2010, 19:00
apalrd's Avatar
More Torque!
VRC #3333
"You will be baked, and then there will be cake"
I actually had a cake once that looked really close to the Portal cake. It tasted good. Maybe someday I will find that picture of it...
Classmate Question: Default Path Location for Driver Dashboard Ziaholic FRC Control System 4 25-01-2010 13:56
Classmate PC lon.bushweiler Control System 8 22-01-2010 14:46
Dashboard not appearing on classmate railerobotics Programming 2 20-01-2010 15:42
Classmate MachineSMMC NI LabVIEW 10 15-01-2010 13:47
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
