Go to Post I used to think FIRST was about my learning experiences, but now that I'm out of high school and am a seasoned veteran of FIRST I've realized that this organization is about more than my own enjoyment, it's about the enjoyment of others. - Jeremiah Johnson [more]
Unread 04-02-2010, 13:11
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
AndyMark Nano Break In
We'll have 4 AndyMark Nanos on our robot this year for the Mechanum drive system. We've learned from experience it's important to break in transmissions on the bench before putting them on the robot and were planning on doing the same with the Nanos. When we did this, though, we're finding a huge range in current draw between Nanos (4 and a spare) with two drawing 11 amps just sitting on the bench, two drawing 6 and one drawing 3 amps!
We haven't run them for the hour or so we typically would but the 11 amp ones get too hot to hold after five minutes. We'd have to run them in bursts to break in. We've looked all through them and can't see anything obviously wrong.
What we've done to the transmissions getting them ready is installed a Nylon spacer on the last stage to keep the axle from sliding back and forth (screwing up the encoder) and switched to the AndyMark aluminum gear in the first stage for weight. The nylon washer has been checked and isn't too tight. All of the transmission have been heavily lubed with SuperLube synthetic grease.
Has anyone else seen similar results? Any ideas of what to try or should we just keep running them and hope they wear in?
Unread 04-02-2010, 13:17
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: AndyMark Nano Break In
We found a whole lot of slop in the Nanos we got. We sent a video to AndyMark and then took the nanos apart and added a spacer (fender washer) to the output shaft to take up the slop. Seems to have worked for us, although we'll be fully testing this on Saturday.
___________________
- Tennyson, Ulysses
Unread 04-02-2010, 13:30
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Which versions of the NANO are you seeing issues with? Is this ont he keyed shaft version or the hex shaft version or both?
Thanks,
Rob
Unread 04-02-2010, 13:35
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
There is one non-sealed bearing in the Nano. If it is not in the right place it will interfere with the fit of the motor. If you look at where the motor mounts that is where that bearing should be. You may have swapped the two bearings when you installed the aluminum gear.
Unread 04-02-2010, 14:03
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
We saw a similar issue when installing a FP planetary to the Nano, the bearing stuck out of the back plate interfering with the mount of the gearbox. How ours was assembled I don't think a CIM would have fit without taking it apart and re assembling it. Because we were are just using the AM planetary we were able to file it down a bit to fit. I'll take some pictures of our problem with them today.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 04-02-2010, 14:16
IndySam's Avatar
Some of the early shipments went out with the wrong bearing. Contact AM and they will send the correct bearing.
Unread 04-02-2010, 13:38
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
To the inside of the casing on the output shaft, correct? We have the hex output shafts, and I'm thinking that we will wind up doing this. Finding spacers for a hex shaft is a pain; the closest one I can find is on sdp-si.com and it's $13.00 for a 3" length. We could go with oversided fender washers, but I'm afraid that they'll rub the outside of the bearing, thus making the whole thing inefficient. So Andy, when you read this, perhaps that's a viable part for next year (Aluminum spacer for 1/2" and 3/8" hex shafts, either a rod stock or individual spacers).
As for the variable burn-in issue, I would presume that it's the CIM gear that's the issue. We found that 2 of the 4 CIM pinions in this year's KOP do not mesh well with the other gears; one downright gets stuck if you let it free-roll. Thus we swapped to a previous year's pinion for the burn in. In the offseason we may experiment with fixing the gears by filing them down a hair.
If you make 10,000 parts, some of them are bound to be bad
GitHub
Unread 04-02-2010, 13:41
AdamHeard's Avatar
Lead Mentor
why does the spacer need a hex?
Unread 04-02-2010, 14:23
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I've done break-in on a number of FRC gearboxes over the years, and let me tell you, it makes a big difference. When running properly, a typical gearbox like the Nano should draw between 2.3 to 2.8 Amps per CIM with no load, from a 12 Volt supply.
Yours are drawing too much. You have something binding.
One year, I had a tight running gearbox, and no way to remachine the plates to increase center distance, and no lapping compound available. I took a bottle of car polish and poured it right in the meshing gears. A few cycles of this, and 20 minutes later, and a bunch of cleanup, and it ran like butter and current draw was less than half of what it started at.
For those of you designing your own gearboxes, make sure to use precision ground bearings. I've seen teams build gearboxes with non-precision general purpose bearings, that just aren't rated for the loads or speed they see, and they fail. I've even seen sloppiness in brand new bearings cause a gearbox to bind enough to nearly stall a CIM.
Unread 04-02-2010, 14:39
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
This is an excellent thread with good information. Thanks for contributing!
As far as "how long to run a gearbox in?" I would say the conditions listed bt Sanddrag for current draw are good. We have typically run KOP Toughboxes for 15 to 25 minutes before getting to those current levels. be sure to monitor motor heat and listen for odd noises that could indicate an assembly problem. Monitoring your current draw with a benchtop power supply is very helpful.
Good luck!
Rob
Unread 04-02-2010, 15:10
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Using a Black Jaguar and BDC-COMM can make breaking-in a gearbox quite easy.
Set your motor to run at a specific voltage in voltage mode, or a specific speed in speed mode (with an encoder), and then monitor the motor current values it spits out. Just like on TV, set it, and forget it! (but not really, be safe and keep an eye on things)
-David
Unread 04-02-2010, 17:09
Jno
here are some photos I've taken of the two issues discussed about the Nano gearboxes. First is our issue with the bearing sticking out and getting in the way of the motor mount, we were able to fix this easily. The second picture shows the slack in the gearbox with the big washer that comes installed.
http://twitpic.com/11e1jk
http://twitpic.com/11e1o6
Unread 04-02-2010, 17:12
CraigHickman
Posts: n/a
Do you break your gearbox in with any sort of lubrication or abrasives? We usually just dump a glob of lithium grease onto the gears during break in, but I'm curious as to how others go about this process.
Unread 04-02-2010, 19:09
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
Jonathan,
You say you fixed the bearing pushing out easily...was with the AM trnasmission I could see how you might make room. How do us CIM folks do it though?
Unread 04-02-2010, 19:14
AdamHeard's Avatar
Lead Mentor
Does anyone know a good way to get current draw using a voltmeter and ohms law?
TB Nano Encoder Spacing daltore Kit & Additional Hardware 5 24-01-2010 11:17
pic: AndyMark has the Nano; we have the Shuffle! rob_c Extra Discussion 10 19-01-2010 22:30
pic: I love the nano Akash Rastogi Extra Discussion 6 02-11-2009 18:19
Lost iPod Nano - SVR Otaku General Forum 0 02-04-2007 21:20
