Go to Post If there's one bit of advice I can give, its never underestimate the power of a hurricane. - Joshua May [more]
Unread 02-04-2010, 03:39 PM
oddjob oddjob is offline
oddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to behold
I2C - Current Address Read
The I2C library Read() code is
Synchronized sync(m_semaphore);
m_module->m_fpgaDIO->writeI2CConfig_Address(m_deviceAddress, &status);
m_module->m_fpgaDIO->writeI2CConfig_BytesToWrite(sizeof(registerAddress), &status);
m_module->m_fpgaDIO->writeI2CConfig_BytesToRead(count, &status);
m_module->m_fpgaDIO->writeI2CDataToSend(registerAddress, &status);
UINT8 transaction = m_module->m_fpgaDIO->readI2CStatus_Transaction(&status);
m_module->m_fpgaDIO->strobeI2CStart(&status);
while(transaction == m_module->m_fpgaDIO->readI2CStatus_Transaction(&status)) taskDelay(1);
while(!m_module->m_fpgaDIO->readI2CStatus_Done(&status)) taskDelay(1);
data = m_module->m_fpgaDIO->readI2CDataReceived(&status);
I'm not sure, but that appears to be a I2C Random Address Read protocol.
Does anyone have I2C code for Current Address Read?
Start -> Address|1 -> Ack -> Data -> No Ack -> Stop
Unread 02-05-2010, 01:20 AM
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: I2C - Current Address Read
The current implementation will read "count" bytes without reinitializing.
So you want to read without sending the register address? If that is what you mean, you should be able to simply use the new "Transaction" entry-point in the I2C class and pass 0 for the sendSize. This was added in the update that came out today.
-Joe
Unread 02-05-2010, 06:06 AM
As usual, you are one step ahead. Thanks.
EDIT - any idea if/when the new sources will be posted at firstforge?
Unread 02-05-2010, 11:47 AM
They have been since yesterday... in SVN anyway.
Unread 02-05-2010, 11:57 AM
I was looking at the snapshot area, and the new source zip file didn't make it to there yet.
snapshot
EDIT - there is a new release there, but it looks like it is the update patch, not the source zip file.
Unread 02-05-2010, 11:58 AM
snapshot
There now.
Unread 02-05-2010, 12:01 PM
Whoops... just put up the team update... not the source... just a few more minutes.
Unread 02-05-2010, 02:31 PM
Sorry for the confusion... the source is now posted as a snapshot.
ADXL345 using I2C tdidi C/C++ 1 01-29-2010 09:02 PM
i2c output virtuald Programming 16 01-18-2009 07:20 PM
what I2C means? matanost General Forum 6 12-11-2008 04:44 PM
I2C tutorials John Gutmann Electrical 3 07-30-2005 10:44 AM
I2C? John Gutmann Electrical 3 07-19-2005 10:52 PM
