Go to Post Don't date anyone on your team unless you are POSITVE that you will be able to handle yourself professionally, not only during your relationship, but even after it ends. - Jaine Perotti [more]
Unread 05-02-2010, 20:32
Team1908 Team1908 is offline
FRC #1908
Team1908 is an unknown quantity at this point
Camera Issues (we have tried practically everything!)
Our team has been having trouble trying to set up the camera so that it returns images to the driver station. This is what we have done so far (in no particular order):
-Installed the driver station update (correctly, so that the compass indicator is showing)
-Used the Axis Camera Setup program from Labview to configure the camera
-Re-imaged the cRIO for Labview using image v10 and built and deployed code to the cRIO (all vision code is still as it was from the default code)
-Ensured that our camera is functional by viewing the live feed through an internet browser on our computer
Assuming that the default code made provisions for sending images to the driver station, the only two things that I can think of are wrong are:
-Requiring the Labview update
-Using the newer v19 cRIO image
The main questions we would like answered are:
-Would not doing either of those things prevent the camera from sending data to the driver station?
-Could anything that we haven't done besides those two things prevent the camera from sending data to the driver station?
Thanks in advance!
Unread 05-02-2010, 21:54
Re: Camera Issues (we have tried practically everything!)
Absolutely, you need both of those.
Unread 05-02-2010, 22:13
FRC #1908
Okay, we'll run both of those and try again.
Unread 17-02-2010, 23:35
FRC #1908
Okay, we have run both of those updates (as well as the updates that were released recently) and re-imaged the cRIO to version 20. We successfully receive images wirelessly now from our robot to our driver station. The only problem is that the added process seems to be lagging our robots operations of all of its other components. Is there any way we can use a delay to slow down how many times it gets images so that our robot will function normally?
Unread 18-02-2010, 06:39
Begin lets you configure how the camera operates. What size, compression, and frame rate is it set to? If you lower the frame rate and possibly the others, I think you'll find a good solution.
Greg McKaskle
Unread 18-02-2010, 06:42
FRC #1908
We simply kept the default parameters that were given to us in the code. Any code pertaining to the camera was never changed from the default.
Unread 18-02-2010, 06:46
The default code is always looking for the target, in all modes. If you don't take advantage of this, you can turn off the button that enables the vision processing. You can also do this programmatically by turning off the global for different game modes, based on a button, etc.
If you want to process for targets, it definitely takes CPU, but shouldn't really affect the way the robot drives. Have you moved the vision code into teleop or something?
Greg McKaskle
Unread 18-02-2010, 07:09
FRC #1908
Greg McKaskle
We aren't taking advantage of the code for finding the target, but we're not quite sure how to disable vision processing.
And no, we did not move the vision code into teleop. The vision code in our project is exactly identical to the vision code in the default project. None of our programmers dared to click on them.
Unread 18-02-2010, 07:15
Just checking about the location.
The Vision Processing VI contains a loop that either sleeps or gets and processes an image. That decision is made based on a global. If you set that global you can control the vision processing. The place the global is currently set is in Robot Main.
Note this processing is independent of the vision back to the PC. There is a similar button beneath the dashboard that will enable and disable the dashboard images. Since those are not processed by the cRIO, the overhead to retransmit is really small by comparison.
Greg McKaskle
Unread 18-02-2010, 07:23
FRC #1908
That's excellent! We're glad that this will (hopefully) de-lag communications between the robot and the driver station without attempting to mess too much with the camera settings. We'll try it this afternoon and see how it works.
Unread 18-02-2010, 15:38
FRC #1908
We set the global for enabling the vision processing to false using a constant, and now the lag is gone. Thank you very much for your assistance.
1726 - practically done! TheOtherGuy Robot Showcase 10 19-02-2008 16:14
Camera Oversaturation Issues? 114Klutz Programming 11 19-04-2007 17:47
Camera Issues RedOctober45 Programming 5 08-02-2007 15:59
Camera issues Todd Programming 0 16-02-2005 19:06
