2010 axis camera
Were a rookie team this year and have hardley any idea what were doing. I have configured the camera as the instructions said to do, but in the web browser on the live view screen. It says that the axis media control has not been installed. Do you have any idea how to get that?
Re: 2010 axis camera
You may want to try viewing the camera's stream in Internet Explorer. If that doesn't work, go in to the settings and look for how it displays the image. Select 'Java Applet' for both IE and other browsers. Doing that made it work well for us.
Good luck! |
If I recall, (and it's been a while since I set up the camera), that is actually downloaded from the camera and installed by your browser when you connect to it.
What browser are you using, and did it alert you that it's trying to install something? (Someone let me know if that's off base - it's been a month since I set up the camera last). |
I suppose you don't have Java installed in your computer, go to the Java website and try to do a "test". it will tell you if you have Java or if you are not current with their updates.
| 2010 Axis Camera Dashboard Problems | Kohala2460 | General Forum | 0 | 04-02-2010 13:34 |
| 2010 Axis Camera Dashboard Problems | JesterKarrde | Programming | 12 | 04-02-2010 13:11 |
| Java/Netbeans Camera Code for Classmate PC and Axis Camera | joshholat | Programming | 1 | 23-01-2010 14:59 |
| Axis Camera | ehochstein | Programming | 2 | 21-02-2009 00:16 |
| AXIS Camera | nickmagus | Programming | 1 | 03-01-2009 20:06 |
