Go to Post It sounds like "whirr" if you do it right, and "clack clack grunge snap @$@%^!!" if you don't. - dtengineering [more]
Unread 06-02-2010, 16:03
mtndurbin mtndurbin is offline
Programming Mentor
mtndurbin is an unknown quantity at this point
Custom Driver station app for classmate
Has anyone developed a custom or modified driver station application to replace Driverstation.exe for running on the classmate PC? If so can you share documentation sources, sample code, or other helpful documentation?
Unread 06-02-2010, 16:41
JDM JDM is offline
programming lead; team executive;..
FRC #2199 (Robo-Lions)
JDM is on a distinguished road
Re: Custom Driver station app for classmate
It's probably possible, but I doubt that anyone has put much effort to it. <R60> allows only the dashboard executable to be modified, not the driver station one.
Are you having some kind of problem with the stock driver station executable?
Unread 06-02-2010, 17:35
Programming Mentor
We just would like a custom display.
Unread 06-02-2010, 19:25
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Then you are talking about the dashboard, not the driverstation. That's an easy mistake to make since people use them nearly interchangeably. The portion that you set your team number on is the driver-station, and cannot be modified. The top portion is the dashboard, and you can customize that (and are encouraged to!)
If you are using labview I believe it comes with the dashboard (prior to being compiled) so that you can modify and play with that as you like.
Unread 07-02-2010, 10:32
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
We created a very nice (but still in testing) Dashboard client (in C#.Net, on the Classmate) and a Dashboard Server (In C++, on the robot)
one of the controls it has is a data graph, and all you have to do is:
(on Classmate)
Create new Project in Visual Studio
Reference the Dashboard DLL
Drag and Drop a DataGraph Control onto the form
Drag and Drop a DashboardDataHub onto the Form
go into the constructor of the form, or a button click, and type
DashboardDataHub1.AddControl(DataHub1);
DashboardDataHub1.StartMonitoring();
(On C++ Robot)
Type in constructor
ZDashboard dash = ZDashboard();
Type in main loop
dash.Add("grph",stick.GetY());
dash.Send();
I don't have the code with me now, but I can get it on tuesday if you are interested. Porting the robot code to Java would be very easy, so you can use Java too.
Watchdog.Kill();
pic: Custom Icons for Driver Station Accounts Phreadumb Extra Discussion 1 02-02-2010 20:58
Classmate Question: Default Path Location for Driver Dashboard Ziaholic FRC Control System 4 25-01-2010 13:56
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Power for Driver Station mutantblond Technical Discussion 26 11-03-2009 01:20
Driver Station for Autonomous shrimp Control System 5 03-03-2009 17:05
