I'm using Java, my code for the Dashboard looks like this:
Dashboard lowDashData = DriverStation.getInstance().getDashboardPackerLow();
lowDashData.addCluster(); {
lowDashData.addDouble(j1.getX());
lowDashData.addDouble(j1.getY());
} lowDashData.finalizeCluster();
lowDashData.addDouble(j2.getX());
lowDashData.addDouble(j2.getY());
lowDashData.commit();
System.out.println("Dashboard updated");
When I run my code, this shows up on the classmate: Quote:
Re: Dashboard not working
You need to make sure you are packing your clusters up in the correct order to the dashboard. If you are using the one that FIRST provided, go in to labview and check it out to make sure you are packing every thing correctly.
How do I do that? I have no idea how to use LabView.
You have to make a new LabView Dashboard project that takes the same amount of inputs into LabView that you are outputting from Java. Use LabView 8.6 on the disc that you got from the FRC KOP. The Dashboard project comes standard. Then you basically remove the inputs from the default project that you don't need and add your own (graphs, LEDs, etc).
Also, we did get that error commonly, too. If you've already made a new Dashboard project, that error is usually from the camera because I don't believe you can use the camera during competition. At least not for sending video to the Dashboard, but it is available for tracking. |
| Camera working in C++ and default dashboard | pafwl | C/C++ | 0 | 03-02-2010 22:06 |
| Deploying not working | bobwrit | NI LabVIEW | 1 | 16-02-2009 22:09 |
| NI Dashboard only partially working? | Tim Skloss | Programming | 4 | 05-01-2009 10:37 |
| p2 not working? | Lone_Wolf92c | Programming | 5 | 22-02-2008 08:49 |
| IR Board Not Working (But NOT Fried) | itsme | Electrical | 2 | 18-02-2008 06:11 |
