Go to Post That settles it, no questions left. Water game. - Lil' Lavery [more]
Unread 07-02-2010, 18:45
nabioullinr nabioullinr is offline
FRC #1073
nabioullinr has a spectacular aura aboutnabioullinr has a spectacular aura aboutnabioullinr has a spectacular aura about
Taking Over the Serial Port (C++)
Is there a way to disable stdout to the serial port, and then use it via the SerialPort class (while retaining network console capability?) - I need a dedicated serial port for an LCD screen. Otherwise I would probably have to bit-bang rs-232.
Unread 07-02-2010, 19:00
JDM JDM is offline
programming lead; team executive;..
FRC #2199 (Robo-Lions)
JDM is on a distinguished road
Re: Taking Over the Serial Port (C++)
The "Console Out" DIP switch on the cRIO controls stdout through the serial port. The network console will work fine no matter how it's set.
Hope this helps.
Serial data out of the programming port Doug Leppard Programming 5 07-04-2008 08:53
Does reading from the serial port work? Alan Anderson Programming 16 29-01-2008 07:15
Programming the vex microcontroller to respond to commands on the serial port crashoverride02 Programming 1 20-10-2006 14:17
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
