Go to Post I wish I had two extra hands, so I could give those gearboxes four thumbs up! - Billfred [more]
Unread 07-02-2010, 23:49
Scribbles Scribbles is offline
FRC #3133
Scribbles is an unknown quantity at this point
Connecting Two motors to one Jaguar Controller?
Well, we've been working on setting up our motor drive system and ran into a bit of a problem.
We've been running each motor to a single Jaguar, but now we're thinking one of the Jaguars might have died on us. I've heard varying opinions on this matter, and basically wanted to see if I could get some solid information.
Basically, would we be able to run both motors connected to a single Gearbox through a single Jaguar, or do we need two control modules, one for each motor on one side?
If we can do this, are there any adverse affects or downfalls, or anything that we should be aware of?
If we can consolidate each side to a single Jaguar, I think it'll make everything much easier, but I wanted to see if anyone has experience with this first before we try and push it.
Thanks for the time!
Unread 07-02-2010, 23:53
Re: Connecting Two motors to one Jaguar Controller?
One motor per Jaguar.
<R55> All electrical loads (motors, actuators, compressors) must be supplied by an approved power regulating device (speed controller, relay module, or Digital Sidecar PWM port) that is controlled by the cRIO-FRC on the ROBOT.
A. Each CIM motor and Fisher-Price motor must be connected to one and only one approved speed controller. These motors must not be connected to relay modules.
Unread 08-02-2010, 10:31
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I believe that rule says one controller per motor. I remember in 2005 we ran two FP motors on one victor because we got the 6V FP motors, and that was legal. I see no advantage to run two motors off of one controller other than cost savings.
The only repurcussion I can think of is that you'll only be able to utilize part of the power of two cims as your electrical power will be limited to ~420watts. Of course it will also be a whole lot easier to pop a single 40Amp breaker with 2 CIMs.
Unread 08-02-2010, 10:34
EricH EricH is online now
Aye, but another rule specifically says no.
<R49> Each power-regulating device (speed controller or relay module) shall control one and only one electrical load (motor, actuator or compressor).
A. Exception: Multiple low-load, pneumatic solenoid valves may be connected to a single relay module. This would allow one relay module to drive multiple pneumatic actions. No other electrical load can be connected to a relay module used in this manner.
(emphasis mine)
Unread 08-02-2010, 10:35
Are you sure? I don't remember any year where that configuration was legal.
Long story short, one controller to one motor. Thems the rules, and its the safe way do it.
Unread 08-02-2010, 10:39
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
It may have been a special exception because some teams, like ours, got FP motors that were only rated to 6v, so running two in series gave you the same current draw at the same voltage as one 12v FP.
Unread 08-02-2010, 15:11
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
you could use a victor, and plus black jaguars can work the same as other jaguars
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 08-02-2010, 15:19
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Running multiple motors of one Victor has never been allowed. No exceptions have ever been issued to bypass that rule. There was a rule exception issued that allowed teams to run 6v Fisher-Price motors at 12v, due to a mix-up in motor models supplied by F-P. But that exception did not allow teams to gang multiple motors on the same speed controller. If any teams were doing that, then their robots were in violation of the rules.
-dave
Unread 09-02-2010, 04:24
Tony.Wu Tony.Wu is offline
Carnassial
AKA: Dave The Mechanic
Team Role: Animator
Tony.Wu is an unknown quantity at this point
Send a message via MSN to Tony.Wu
One motor per controller.
Unread 08-02-2010, 00:22
Phoenix Spud's Avatar
Phoenix Spud Phoenix Spud is offline
Everyone. Everywhere.
FRC #3132 (Thunder Down Under)
Phoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond repute
As Mark pointed out, this would be illegal. Our team thought the same thing, luckily we double checked the manual. If you think that your part is dead, I would suggest a quick order to AndyMark.
Sarah Heimlich
Outreach Mentor | Business Mentor
FIRST® TEAM 3132
Unread 08-02-2010, 09:40
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Actually, Andy-Mark does not sell Jaguars, you can order them at a specially discounted price for FRC from Digi-Key.
It looks like they only have the Black Jaguars in stock.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
pic: Jaguar Speed Controller Padre_Vez Extra Discussion 15 31-01-2009 14:41
Jaguar Motor Controller Problem prashil27 Electrical 5 07-01-2009 21:21
connecting Jaguar to Sidecar Lakedaimon Electrical 2 15-12-2008 01:04
Connecting the controller Max Brin Technical Discussion 1 12-01-2006 11:24
Connecting FP Motors to stuff Matt Krass Motors 5 28-07-2003 17:40
