Go to Post it seems to have all the basic food groups: liquid, sugar, sauce, and robotics components. - ChrisMcK2186 [more]
Unread 08-02-2010, 21:57
zip100 zip100 is offline
FRC #0640
zip100 is an unknown quantity at this point
coding help
How can I do the exact opposite of the code I wrote. Instead of pressing button 1 for half speed I want it to press button 1 for a turbo boost and regular would be .5
Unread 09-02-2010, 10:22
Re: coding help
The Boolean palette contains a negate icon, and you can place that in front of the case. Another, possible easier to read way of doing this is to right click on the case and at the bottom Make this case ... will allow you to choose which code goes with which button logic.
Greg McKaskle
Unread 09-02-2010, 12:26
Re: coding help
I think we might have misunderstood what you were asking in an earlier thread. When you say you want the motor to run half speed, do you want it to run at half of its maximum speed, or do you mean you want it to run at half of whatever speed the driver is commanding via the joystick?
If your goal is to make the joystick half as sensitive, you don't want to wire a constant 0.5 into the drive vi. You want to multiply the joystick axis value by 0.5 instead. Use your joystick button to send the value straight through without the multiply in the "turbo boost" case.
Website coding help needed Tottanka Programming 5 05-01-2007 07:22
coding problem!! HELP! wildabyss Programming 7 21-02-2005 21:48
PHP Coding HELP!!! FRANK(WGH) Website Design/Showcase 9 26-01-2005 17:18
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
coding, motors, spikes, help archiver 2001 3 24-06-2002 00:48
