Go to Post It doesn't make a team better if they have just one sponsor or if they have 100 sponsors. However, you should commend a team who struggled to pay the bill with a list of sponsors one hundred long for showing their strength, perseverance and love for participating in the FIRST robotics program. - MikeDubreuil [more]
Unread 09-02-2010, 12:07
interplanetary interplanetary is offline
AKA: Camden
FRC #3168 (Warriors)
Team Role: Communications
interplanetary is an unknown quantity at this point
Button programming help
My team is trying to program our joysticks to where the trigger button on a Logitech Attack 3 controller is used for throttle on our bot (like a throttle button on a video game) So if we hit the joystick and are not holding the trigger the bot won't move. I was wondering if anybody has the code or can tell us how to write the code to do this, help would be apperciated. we are using tank drive. We are using Java to program our robot.
Unread 09-02-2010, 12:21
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Re: Button programming help
You can use the getTrigger() method on a Joystick to determine whether or not the button is being pressed. If it is, call the tankDrive() method, and if it isn't, tell the robot to stop driving. This could be done by calling drive() with 0.0 as the speed and curve values.
Example:
// Assumptions: these are already set up and configured.
RobotDrive drive;
Joystick leftStick, rightStick;
// In teleop control:
if (rightStick.getTrigger())
    drive.tankDrive(leftStick, rightStick);  // Drive when trigger is pressed
else
    drive.drive(0.0, 0.0);          // Stop driving if trigger is released
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 10-02-2010, 09:59
joshholat joshholat is offline
FRC #0930
joshholat is an unknown quantity at this point
Yup, that's about all you'd need. Just make sure you aren't destroying the gearboxes by like going full speed and then hitting the trigger to stop movement instantaneously.
Unread 17-02-2010, 13:01
chris janney chris janney is offline
FRC #3266
chris janney is an unknown quantity at this point
so would it be similar to do that with a pendulum style kicker. we are using springs and pistons to power to kicker
Button Programming Error? pyr0b0y NI LabVIEW 5 06-04-2009 17:18
Joystick Button Programming in Labview Help Needed domoarigato NI LabVIEW 11 28-01-2009 10:55
Programming a joystick button... programmr Programming 2 05-01-2009 16:13
button programming joesmomh00haha Programming 12 10-02-2007 10:36
Joystick Button programming Bharat Nain Programming 5 18-02-2005 11:48
