Go to Post Maybe we'll see some awesome Game change like.... CARPET! - thefro526 [more]
Unread 09-02-2010, 17:51
brianelite brianelite is offline
FRC #2898
brianelite has a spectacular aura aboutbrianelite has a spectacular aura aboutbrianelite has a spectacular aura about
Watchdog not fed
Hi - I am running 2010imagedemo code...
when I enable the robot in the driver station it says "watchdog not fed" for a few seconds and then the message goes away... and it goes into one of the three modes.
Is this normal? And if not what can I do to fix it?
Unread 09-02-2010, 20:26
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Watchdog not fed
yes, this is normal due to the line that says
GetWatchdog().SetExpiration(1.0);
Wait(3.0);
Whoever wrote this was not thinking clearly
Watchdog.Kill();
Unread 11-02-2010, 09:29
pilum40 pilum40 is offline
Steve Miller-Coach-Team 3355
AKA: Steve Miller
FRC #3355 (Bigg Redd)
pilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud of
We're noobs so our question may be dumb...
If the driver's station goes into auto mode after a few seconds, one, what do we do if it STAYS in watchdog not fed mode, two, does anyone have a patch we could install to overwrite the existing code that doesn't work, three, how do we turn watchdog off? There is not a switch (green switch) on our copy of the software.
I know y'all are laughing but hey...we gotta' ask! Cut us some slack already!
Steve Miller
Coach 3355
Unread 11-02-2010, 15:45
byteit101's Avatar
GetWatchdog().SetEnabled(false);
HOWEVER, YOU SHOULD NOT DO THIS UNLESS YOU HAVE A VERY GOOD REASON, LIKE A BUNCH OF Wait STATEMENTS.
GetWatchdog().Feed(); is your friend
Watchdog.Kill();
Unread 11-02-2010, 16:47
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Rather than disabling the watchdog (not a safe thing to do), you can also set the expiration of the watchdog to something like 5 seconds. That way, if your system hoses, the robot will automatically stop after 5 seconds.
e.g.,
GetWatchdog().SetExpiration(5.0);
Unread 14-02-2010, 02:44
NullEntity's Avatar
NullEntity NullEntity is offline
AKA: Bryce
FRC #0093 (N.E.W. Apple Corps Robotics)
Team Role: Scout
NullEntity is an unknown quantity at this point
I know (using LabVIEW) our team had this issue. Turns out we had to reset the robot each time. I'm not sure if they solved it though.
My Analogy:
  • Buy dog = Turn on robot
  • Dog is hungry so he doesn't listen to you = Watchdog Not Fed
  • Shoot dog = Turn off robot
  • Repeat = ...
FRC Team 93 Alumni
Unread 14-02-2010, 10:19
byteit101's Avatar
you don't have to kill the robot to solve the watchdog not fed error, just feed it (or give it a larger Expiration)
my interpretation of the watchdog analogy:
there are two Watchdogs, System and user. The user watchdog is a poodle that you can kill at will. you also have a poodle re-animation device. On usercode load, you create a new poodle, and you can set its fatness (time to starve) via the SetExpiration. You must feed the poodle within this period, or it dies, falls down, and shorts the motors, so you cannot move until you re-animate it and it gets off the shorted circuts. so you feed it, and re-animate it, and you can continue
Watchdog.Kill();
Unread 25-02-2010, 18:16
NullEntity's Avatar
AKA: Bryce
Team Role: Scout
I think it was fixed by now (I''m not on Controls), but that's what we had to do.
FRC Team 93 Alumni
Unread 06-03-2010, 23:06
pfreivald's Avatar
AKA: Patrick Freivald
I don't know if this is useful at this point, but after struggling with watchdog issues throughout the build season, we corrected it by putting a 5 ms wait statement in our main loop. That cured the problem instantly, and it didn't come back.
(I'm not at all a programmer, but I know that's what they did, so I thought I'd share it here. Good luck teams!)
Patrick
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 07-03-2010, 12:56
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
bronxbomber92 is an unknown quantity at this point
Patrick
I'll expand upon what we did :-)
We were experiencing system level watchdog "not fed" errors. For awhile we couldn't figure out what exactly was happening except that it had to do with the camera feed on the dashboard. It turned out that we were starving the background task/thread that was responsible for serving the dashboard with the camera image packets by hogging CPU time with our main task/thread (the thread that OperatorControl() runs within). This affected our communication between our driver station and cRIO, effectively timing-out the watchdog that monitored communication.
The fix was to suspend the main thread for 5/100 of a second, thus giving other threads (ie, the camera feed thread) more time to execute.
void OperatorControl() {
    while(IsOperatorControl()) {
        ... do you own work ..
        .. then at the end of the loop, suspend the task ..
        Wait(0.05f);
Unread 07-03-2010, 13:47
pfreivald's Avatar
Thanks, Jedd.
Team 1551
I write books, too!
Unread 09-03-2010, 09:21
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
the 5/100 of a second seems plausible, any guesses if this will work for labview too? I'm sure it would, but i'd like other input
"Don't worry, programming can fix it"
"watchdog not fed" error Lumit NI LabVIEW 8 04-02-2010 18:45
Watchdog Not Fed but, All Systems Are Go. DHSrobotics Java 4 24-01-2010 22:01
Watchdog not fed ahudson Programming 1 22-01-2010 11:26
Fed Ex Airbill Troubles Eric Reed General Forum 12 19-02-2007 14:31
fed-ex shipping question brennerator General Forum 2 23-03-2005 07:09
