Defective Ethernet Port on FRC Laptop
Our laptop provided with the kit has a defective ethernet port. If we connect an ethernet cord to the laptop it becomes loose. The only way we can hold it in place is by using masking tape. It works but over time it still gets loose. Does any one have the same problem as us? Also, does anyone have a solution to our problem? We are open to any suggestions and ideas, thank you for your time.
Re: Defective Ethernet Port on FRC Laptop
are you sure it is not the cable? the clips on those type cord often break. try another cable.
From http://www.usfirst.org/frccontrolsystem
| cRIO's Ethernet Port Randomly Disconnecting? | TD912 | Electrical | 5 | 17-01-2010 09:30 |
| How to prevent broken ethernet port on DS | Bharat Nain | FRC Control System | 32 | 18-03-2009 11:25 |
| Driver etation ethernet port 2 died! | RossC | Programming | 6 | 15-02-2009 01:13 |
| Dell laptop serial port | notquitehere188 | Programming | 18 | 26-10-2006 22:32 |
| Horror Story - Laptop com port again | Lloyd Burns | Programming | 3 | 17-03-2003 07:33 |
