Go to Post FIRST does not follow patterns. - Mike Soukup [more]
Unread 09-02-2010, 19:33
lookitsnichole lookitsnichole is offline
FRC #2545
lookitsnichole is an unknown quantity at this point
Classmate battery not working?
Seconds after we unplug our Classmate PC it dies. Also, in the power options in the control panel it doesn't even recognize that there's a battery at all. Has anyone else had this problem? We assume we need to replace the battery, but perhaps it's some other issue?
Thanks
Unread 10-02-2010, 00:01
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Classmate battery not working?
I'd recommend going to the 2go pc helpdesk to see about the problem. You absolutely need to get it fixed, since from what I've heard there will be no wall outlets this year at the alliance stations
Crio not communitcating with Classmate! voteforandy1 General Forum 1 22-01-2010 21:50
Camera not sending image to Classmate? TPNigl Programming 14 22-01-2010 17:05
Dashboard not appearing on classmate railerobotics Programming 2 20-01-2010 15:42
Classmate not loading Dashbaord on bootup gokul Control System 2 13-01-2010 10:34
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
