Rookie scouting coordinator requesting input
I'm a rookie scouting coordinator for my team this year, and seeking input and/or some constructive criticism on my scouting system ive developed for this year. Attached are the sheets ive made for my team to do their scouting, both match and pit. My system involves randomly pairing up my team members with each other, then randomly assigning them teams that they have to fill out a pit scouting sheet for. Then that same pair of people will randomly be assigned certain matches that they have to scout during and a specific alliance station they have to scout for where they will fill out a match scouting sheet (attached below) based on the directions (match scouting sheet directions) The match assignment sheet i have attached should help to better show what i am trying to explain. any input would be very helpful, thanks
Re: Rookie scouting coordinator requesting input
the scout sheets look very nice and professional... one thing that i recommend is that you make the playfield diagram a little bigger... i was a scout for my team last year and i found using a small field diagram can be a little tricky... looks good though...
thats what some of my team members told me as well, but ive stretched the field diagram as far as i can while still keeping it to one page
Also on your match scoring sheet I would add a spot for match number. Looks like a great start so far!
updated version of my match scouting sheet
second one looks much better... good luck this year
#7
It like a great system depending on how many people you have to help you scout. Last year we had papers to fill out with a similar amount of information and we had to have quite a few people helping along with our scouting team to be able to fill it al out, so as long as you have enough people you should be fine. Nice job!
#8
For your Pit scouting I think you captured most of the relevant information except for Autonomous Period. If you added a section asking what Autonomous routines the team had that would round out your sheets.
The other issue I had with your Pit scouting sheet is the part where the team signs off on the sheet. What was your reasoning behind asking for that? As for your match scouting sheet the information is extremely subjective. I have found in the past that if the scouting sheet is too subjective than you cannot determine a realistic account of what the robot can and cannot do. What I would suggest is for the match scouting sheet come up with some more questions that ask for objective results (# Balls scored, # balls kicked, etc...) |
#9
2. the signature is there in an attempt to crack down on people that slack off and do not do their pit scouting because last year the scouting team would hand out clip boards with blank forms and get them back with the same blank forms. At the worst, mentors from my team found clip boards with blank forms scattered around the arena. |
#10
.pdf version of the scouting presentation i plan on giving to my team, any thoughts?
#11
Autonomous header is spelled wrong. Thought you ought to know.
#12
I agree what was said before with the subjectivity to your match scouting sheet. If you make it easy and just allow the scouters to just circle things like did the robot hang? yes/no. how many balls kicked? ___ how many balls scored? ___ any penalties? yes/no final score blue____ red____, etc.. This will give you better data for alliance selection and will make it easier and faster to filter through than, this robot moved forward in autonomous and then they moved around and kicked some balls and then they did this and then they did that then they tried to hang, overall I'd say this was a good robot.... numbers are better than peoples opinion and if you give a set place where the numbers will always be it will allow everything to be accumulated faster when you want stats on a team and stuff for matches and alliance selection
#13
Maybe combine both then? Circles + numbers with room for explanation?
| requesting professional development points? | cjohnson | National Instruments LabVIEW and Data Acquisition | 1 | 23-02-2009 02:40 |
| Robotics Coordinator for School District | Coach Norm | Robotics Education and Curriculum | 4 | 23-12-2008 14:03 |
| Requesting Parts from Igus | neoshaakti | General Forum | 4 | 27-01-2008 20:08 |
| Requesting Inventor Files | Dylan Gramlich | Inventor | 3 | 05-11-2006 00:56 |
| 2.5 is alive !!!! (input ! .. more input ! ) | Lloyd Burns | Programming | 2 | 14-01-2003 19:15 |
