Chain Generator
ok, i used the roller chain generator, and it said this:
"chain drive trajectory is corrupted or data are inconsistent with build in rules. calculation cannot continue" and "no sliding sprocket within the chain drive. please set one sprocket as sliding." i was using the output sprocket and the wheel sprocket that autodesk has in their KOP download, and i'm 100% sure that they are in line because I constrained them in line using a flush. can anyone help me? |
Re: Chain Generator
hello? anyone there?
Re: Chain Generator
I would just try deleting the constraints on the sprockets and then try generating the chain to see what happens. if that doesnt work, double check that the sprockets arent constrained to anything else.
Re: Chain Generator
thanks, i'll try that
| CIM generator | Cirrussport | Motors | 16 | 22-09-2006 10:47 |
| Chain Drive chain | Damelvin | 3D Animation and Competition | 2 | 15-02-2005 00:19 |
| Vacuum Generator | Peter Matteson | Pneumatics | 0 | 04-02-2005 15:58 |
| Vacuum Generator | Peter Matteson | Technical Discussion | 0 | 04-02-2005 15:58 |
| Chain and chain breaker source? | kmcclary | Off-Season Events | 4 | 22-10-2001 22:51 |
