Go to Post The Tekin's used to constantly suffer from spontaneous combustion, it was extremely frustrating how often they would go. - Kingofl337 [more]
Unread 10-02-2010, 21:32
yoshibrock's Avatar
yoshibrock yoshibrock is offline
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
yoshibrock will become famous soon enoughyoshibrock will become famous soon enough
Send a message via AIM to yoshibrock
Is this legal (Bumpers)?
Is this legal? Sorry about the quality by the way, I draw faster by hand then in paint
http://picasaweb.google.com/lh/photo/STRXhahvXQF64xMHxX2wBg?authkey=Gv1sRgCOC8s6vpmcqtK g&feat=directlink
The bumper goes inside the c-brackets, which are mounted on a piece of the kit frame. This is what's currently on our robot, and it takes a bit of work to get big c-channel, so we'd like it to stay if possible.
However, I'm worried that it wouldn't be considered "Robust" by the inspection officers, but I'm not sure. What do you think?
There is no charge for awesomeness.
Am I a hero? I really can't say, but yes.
Unread 10-02-2010, 21:47
yoshibrock's Avatar
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
Re: Is this legal (Bumpers)?
I'm not completely sure, but I think the bumpers will slide into the c-brackets and be pinned/bolted in place. What worries me more is whether or not the "kitbot" chassis bar is wide enough (up and down) to be considered robust. It feels robust, but even I admit that it looks kinda wimpy
And I'd like to show a picture, but it's kinda secretive....plus I don't have a picture.
Unread 10-02-2010, 21:52
nitneylion452's Avatar
AKA: Joe Lee
I don't think so, namely because the c brackets may be called part of the frame, or because the connection will not be robust. Here's a suggestion that has no gray area (It's what we're using on our robot):
http://www.mcmaster.com/#threaded-inserts/=5rizbc
Hope that helps.
(Ignore what I said before)
Unread 10-02-2010, 22:08
yoshibrock's Avatar
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
What exactly are the inserts to be used for? The c-bracket part of the frame is liable to change to fit rules. It's the other part, the part the c-brackets are mounted on that worries me. Thanks for the suggestion though.
Unread 10-02-2010, 22:29
AKA: Joe Lee
You would put the inserts into the plywood and put a bolt in through the opposite side. This gives you the ability to remove the bumpers simply by removing a few bolts.
Unread 10-02-2010, 22:32
yoshibrock's Avatar
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
Oh! That is a good idea, thanks. But what do you think about using the kit-bot frame as a holder for the bumpers? Is it strong enough?
Unread 11-02-2010, 17:59
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Something like this? This is the one our team is using, and it's working spectacularly well.
Unread 11-02-2010, 18:23
Hito Seika's Avatar
Hito Seika Hito Seika is offline
aka Garrett
FRC #1225 (Amperage Roboticcs)
Hito Seika is infamous around these partsHito Seika is infamous around these partsHito Seika is infamous around these partsHito Seika is infamous around these parts
Hay when you attach your bumpers to the robot, do you have to use the bolts like in Figure 8-1 in the rule book?
Sorry about my spelling ….I’m a horrible speller
Unread 11-02-2010, 18:33
EricH EricH is online now
The specific wording is found in <R07-I>:
I. BUMPERS must attach to the FRAME PERIMETER of the ROBOT with a rigid fastening system to form a tight, robust connection to the main structure/frame (e.g. not attached with Velcro). The attachment system must be designed to withstand vigorous game play – nut and bolt fasteners are recommended. All removable fasteners (e.g. bolts, locking pins, pip-pins, etc.) will be considered part of the BUMPERS.
Unread 11-02-2010, 19:12
It is hard for me to make a decision on the drawing alone. The first thing I would question is whether this design allows for the 1" limit for hard parts in the bumper here...
N. “Hard” parts of the BUMPER (i.e. plywood backing, fastening system, and clamping angles) may extend up to a maximum of one inch beyond the FRAME PERIMETER. “Soft” parts of the BUMPERS (i.e. pool noodles and cloth covering) may extend up to 3½ inches beyond the FRAME PERIMETER.
The second would be the method of attachment as it applies here...
The third would be to check that the support structure is in fact entirely within the bumper zone.
And finally a quick check of the various Team Updates and Q&A responses pertaining to sizing, FRAME PERIMETER, and frame structure.
I am not sure that your design would pass the test on all of these.
Unread 11-02-2010, 22:06
yoshibrock's Avatar
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
Thanks for all the help everyone! Out of concern for the legality of our bumper system, we've decided to update our "bumper frame" per se to full sized c-channel. We'll ensure we follow all the other rules as well. Thanks for the help, and good luck in these last couple of weeks!
pic: Second year team needs your help: Are these bumpers legal?!?!!? Tyler Olds Extra Discussion 28 10-02-2010 23:47
Touchsensors in the Bumpers legal? Kevka Electrical 8 25-01-2010 14:25
Is this legal? indubitably Rules/Strategy 9 10-01-2010 03:20
2 sets of bumpers legal? ChuckDickerson General Forum 33 07-03-2009 12:37
is this legal? natalie604 Pneumatics 5 31-01-2008 10:03
