Go to Post What? Thinking is required? I certainly hope not! If so, I'm toast! - Robert Cawthon [more]
Unread 11-02-2010, 20:35
scottbot95 scottbot95 is offline
FRC #1388 (Eagle Robotics)
scottbot95 is an unknown quantity at this point
Cypress First Touch
We have programmed the PSoC with the PSoC Programmer but the Driver Station won't recognize its existance.
I saw a post somewhere were someone had the same problem, if you could direct me towards that thread or answer on mine that would be great.
Unread 11-02-2010, 23:43
Re: Cypress First Touch
Do you mean you downloaded the FRC firmware, or do you mean you wrote your own program and downloaded that?
I only ask because for Driver Station use requires the FRC firmware.
There is an issue that requires us to uninstall the Cypress s/w and reinstall it.
That can be done using the Driver Station Update.
Unread 15-02-2010, 22:14
Thanks for your help. we did that a third time and it worked
Cypress board bls0620 Electrical 4 17-01-2010 23:22
Cypress Board Configuration Geek 2.0 FRC Control System 12 17-01-2010 04:23
Cypress IO board connect SteveD FRC Control System 12 16-01-2010 16:46
Cypress soc? sp33chy FRC Control System 2 15-01-2010 08:58
get in touch with the members of the First Program lil devil Chit-Chat 30 23-03-2002 22:50
