Go to Post Doughnuts would probably be a pretty good alternative to churros. However, that could be open to debate. - Calvin Hartley [more]
Unread 12-02-2010, 22:13
Robopanda6 Robopanda6 is offline
FRC #2477
Robopanda6 is an unknown quantity at this point
Compressor Code
We've tried using samples of compressor codes from other teams that said their code works correctly but when we try to run our code it runs correctly but our compressor isn't turning on. Could i see other codes or does anyone have any suggestion?
It would be very aprecciated.
"They say the struggle only sweetens the success"...I guess that's why I stayed in Robotics.
Unread 17-02-2010, 13:31
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Re: Compressor Code
I don't know if this will help, but we have had several team members "correct" the wiring by moving the pressure sensor input or relay output to the PWM connectors.
The pressure sensor should be wired to the DIO pins and compressor spike relay to one of the relay outputs on the digital sidecar (and obviously the physical wiring needs to match the channel numbers in the code).
Bizarre issues with compressor code Rafael Vasquez Programming 2 10-02-2010 22:26
Compressor Code causes No Robot Code Error sircedric4 C/C++ 25 03-02-2010 10:13
Automated Air Compressor code ShotgunNinja Programming 12 14-02-2008 15:52
Compressor Code gacp Programming 2 19-02-2005 16:18
Help With Compressor Code fred Programming 6 21-01-2005 17:40
