Belt Material
How do you alter the size of drive belting? We tried heat and that makes it crumple. Thank You
Re: Belt Material
What you can do to change belt sizing depend on how your drive belt is fabricated.
See http://www.mulhernbelting.com/belt_fabrications.php If your belt uses a splice you can undo the lacing/metal fastener you can undo the connector and slice a little bit off the belt and then reproduce the splice. If your belt is endless or uses a splicing method you can't reproduce in your shop (based on your original post this seems likely). Then you need to add a tensioning pulley to your drive train. This mean that you need to add a pulley in a position that makes the pulley tight (bonus points if you make it adjustable). There are numerous threads here on CD on how to do it. |
| Belt material | Michael Leicht | Technical Discussion | 1 | 15-01-2009 21:14 |
| Broken Belt | m3ch4num470r | Technical Discussion | 15 | 21-08-2008 10:28 |
| Conveyor Belt | Setsanto | 3D Animation and Competition | 2 | 21-01-2008 20:51 |
| [OCCRA]: Belt material and wheel modification | JBotAlan | OCCRA Q&A | 1 | 19-09-2007 21:15 |
| type of material; conveyor belt | Alyssia | General Forum | 9 | 10-01-2003 13:06 |
