Go to Post You have no idea how happy I am that so many are taking an interest into accomadating their off season competitions for pre-rookies. - Keith Chester [more]
Unread 13-02-2010, 11:38
Dawl Dawl is offline
FRC #2549 (Millerbots)
Dawl is an unknown quantity at this point
Watch Dog not fed?
My team and I are trying to get our autonomous working. After we upload code and enable in autonomous mode it give the error "Watch Dog not fed". What does that mean. If you could point us toward another thread or give us any help we appreciate it.
thanks
Unread 13-02-2010, 12:34
Re: Watch Dog not fed?
bump
Unread 13-02-2010, 12:47
If the robot works fine in teleop, it likely means that the autonomous code completes and is no longer looping, feeding the watchdog.
If you place a target in front of the robot, slightly off to one side, the default will rotate to face the target. The comments in the sample code may help guide you towards completing the routine.
Greg McKaskle
Unread 13-02-2010, 12:50
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
If you can find where it stops, you just need to feed the watchdog there. In java, it's done like this:
Watchdog.getInstance().feed();
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 13-02-2010, 13:02
After further testing it seems to take about 15 seconds before the watchdog gets fed. After that happens the autonomous works fine. Anyone know what causes the delay or how to get rid of it.
Unread 13-02-2010, 13:03
Lead Programmer
AKA: Socks
Are you using Autonomous independent or iterative?
Unread 13-02-2010, 13:12
dona klarson dona klarson is offline
dona klarson is an unknown quantity at this point
hello we r team 1946
we had the same issue but we realized that we made the mistack of putting our code before the
PHP Code:
so make sure the whatchdog is the first function in the class
Team1946
Watchdog not fed brianelite C/C++ 12 14-03-2010 14:43
Autonomous Independent Code Issue Watchdog not fed pilum40 FRC Control System 0 11-02-2010 12:00
Watchdog Not Fed but, All Systems Are Go. DHSrobotics Java 4 24-01-2010 22:01
Watchdog not fed ahudson Programming 1 22-01-2010 11:26
Driver Station Watch Dog / Motor Won't Spin Issue RMiller FRC Control System 5 20-01-2009 09:58
