Go to Post Theory is a nice place, I'd like to go there one day. - JamesCH95 [more]
Unread 13-02-2010, 12:20
Aaron V Aaron V is offline
FRC #1325 (Inverse Paradox)
Aaron V is an unknown quantity at this point
cRio Communications Fail
We've just recently updated everything with the new updates (NetBeans plugin, DS and cRio image), but when NetBeans tried to download code to the cRio, it fails. It appears to be looking for version 19, but we have version 20.
The similar error happened earlier on, but the was a matter of updating the cRio and not NetBeans. This time I'm pretty sure NetBeans needs an update. I don't think I missed any of today's updates, but maybe I did.
Anyone have any thoughts?
Unread 15-02-2010, 00:12
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: cRio Communications Fail
There is some xml file in the netbeans folder where if you change some text that ends with "v19.zip" to "v20.zip" it all should work. The search function is your friend
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
bridge/cRio communications sporadic nathanww FRC Control System 23 22-02-2010 15:00
Camera Config Fail. Thundr Whale Programming 4 13-02-2010 13:32
Solenoid is teh fail Nick Seidl Pneumatics 23 25-01-2010 13:07
cRIO communications problem alex42 FRC Control System 5 16-01-2010 20:22
DS and cRIO Not Maintaining Communications Will_Sica FRC Control System 0 10-01-2009 13:39
