Go to Post Question: How can you tell the difference between an engineer and a programmer? Answer: You ask them to count. Engineers start counting from 1. Programmers start counting from 0. - Ed Law [more]
Unread 02-13-2010, 03:03 PM
frenchie4111 frenchie4111 is offline
None #1111
frenchie4111 is an unknown quantity at this point
Time in Milliseconds
We are trying to program our robots kicker and we are having a problem with inacurate time delays because we can not get the time in milliseconds.
[url="http://mylifeisnerdy.co.cc"]My Life Is NerdyURL]
Unread 02-13-2010, 03:24 PM
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
bronxbomber92 is an unknown quantity at this point
Re: Time in Milliseconds
What are you using currently to get the time?
GetTime() has nanosecond resolution, Timer::GetFPGATimestamp() has microsecond resolution, and the Timer class has microsecond resolution.
Unread 02-13-2010, 03:30 PM
None #1111
Oh we were using the time class (time.h). We did not notice the timer class.
Unread 02-13-2010, 06:47 PM
By the way, changing the resolution of the clock using low level VxWorks routines may wreak havoc on the timing of the rest of the system. Obviously you can do so, but do it carefully and test well.
Greg McKaskle
Unread 02-13-2010, 07:02 PM
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
use Wait(double seconds);
or a Timer
Watchdog.Kill();
Unread 02-22-2010, 05:56 AM
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
BTW, in case you haven't found an optimal solution, I just implemented a GetMsecTime() macro today. The timer object seems a bit heavy to me. This is simple yet functional.
#define GetMsecTime()           (GetFPGATime()/1000)
Unread 02-22-2010, 08:47 AM
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
If you want something simple and fast, use the standard C library's ctime (also known as time.h).
the function clock() returns the amount of ticks that have passed since your program started running as a clock_t value. The amount of ticks per second is defined in the macro CLOCKS_PER_SEC. Using this and some simple dimensional analysis, you can easily get how many miliseconds have passed between two clock() calls.
Unread 02-13-2010, 03:28 PM
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Hmm... Well, I'm sure that there's something buried in the WPILib that can do it for you like using the time() function. But, from a VxWorks perspective, you can issue a:
-> sysClkRateGet()
This will tell you the interrupt rate of the system clock. And, sysClkRateSet(100) would set the interrupt rate to 100 Hz (10 ms clock resolution).
With that, tickGet() will return the current clock tick count with subsequent calls allowing you to measure elapsed time to the resolution of the system clock.
And, taskDelay(1) is a delay of 1 clock tick (10 ms at 100 Hz). You can also create watchdog timers that will attach your code to the system clock interrupt service routine and run it at a specified delay. Again, I'm sure that there's something buried in the WPILib that can provide what you're looking for, but I know VxWorks a lot better than I know the WPILib.
HTH,
Mike
Running Motor for X Milliseconds DWirth NI LabVIEW 2 02-10-2010 07:54 AM
It's that time of year again!! (No, not The Championship event) Tax Time!! Elgin Clock Chit-Chat 4 04-10-2005 10:59 AM
time? roeperJTD06 OCCRA 1 11-21-2003 06:03 PM
time archiver 2000 3 06-23-2002 10:58 PM
