Go to Post After all, each day is fresh with no mistakes in it [yet]. - atomikitten [more]
Unread 15-02-2010, 11:01
DynamiteHack DynamiteHack is offline
FRC #2988
DynamiteHack is an unknown quantity at this point
Changing gearing
Our team has been working on a kicker which uses a CIM motor connected to a toughbox. Upon completion, we found that it wasn't spinning fast enough to kick the ball more than 5 feet or so. Unfortunately, the toughbox uses a different shaft for the drive gear than for the others, so it isn't just a matter of swapping gears.
My question is, is there a way to change the gearing in a toughbox? Specifically, is there a hex-shaft available which will fit over the motor shaft in order to make the other gears fit on it?
Unread 15-02-2010, 11:05
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Re: Changing gearing
Yup, check out optional gear ratio at the AndyMark Toughbox page:
http://andymark.biz/am-0145.html
Very easy to purchase different sizes gears from AM and change the gear ratio.
-Ken L
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 15-02-2010, 11:06
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
You can do some minor work to one of the end plates, and move the gears around to get rid of the second stage of gear reduction. This will give you a 3.57 (?) ratio instead of 12.75:1 which is quite an increase in speed.
You didn't say what ratio you want....this may or may not help you.
Unread 15-02-2010, 15:22
AdamHeard's Avatar
Lead Mentor
If you add the mounting holes for a CIM around the 7/8" bearing hole that is used for the intermediate stage, that's a real easy way to do what squirrel is talking about.
Also, the final stage is currently 14:50 in a toughbox, AM sells several replacements for that stage, up to 24:40 I believe.
Unread 17-02-2010, 18:15
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
you don't even have to use a gearbox, you could just use a straight-up cim.
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Gearing Up! (FIRST documentary) gearingup General Forum 59 30-10-2013 03:19
DC Motor and Gearing Red-Rx7 Motors 18 22-03-2008 16:35
Gearing Ratios satyam Motors 1 31-01-2004 09:50
Gearing Calculator Gui Cavalcanti Technical Discussion 6 09-08-2002 10:06
Gearing down? nerdy Technical Discussion 2 14-01-2002 00:15
