Go to Post No one would climb Mount Everest before climbing the hill in the park down the street. - RbtGal1351 [more]
Unread 16-02-2010, 02:14
elbuo elbuo is offline
Teams #2884 and #1144
AKA: Yamil Asusta
FRC #1144 (Coquitron)
elbuo has a spectacular aura aboutelbuo has a spectacular aura aboutelbuo has a spectacular aura about
Several questions...
I wish to know how to create several autonomous versions. I know in VEX I could add and remove a jumper from the micro and it would execute different tasks. I wish to know if there is a simple way to do this in FIRST.
Maybe using a limit switch?
Also, I was asked to code a special drive system. It's a semi-swerve drive. Wheels can only turn 180 degrees. They are all connected by the same chain so there is no need for encoders. But I wish to know if I had to program each motor independently or if there a way to do this easily.
It has a motor for each wheel (4). And there are 4 motors controlling the chain which make the wheels turn. I coded the limit switches but I wish to know how I can implement the code correctly. Since the robot wasn't wired, I don't know if the code I left them will work correctly. I couldn't test and debug and I won't be able to do so until Saturday when I meet them again.
Aluminum sprockets for drive train - several questions M. Mellott Technical Discussion 16 16-12-2008 15:53
I have several question starsROBOTICS Programming 9 10-09-2008 11:06
Several questions Amittt 3D Animation and Competition 8 02-02-2006 18:21
