Go to Post This has to be the strangest trolling/spam/anything I've seen on CD, ever. - frcguy [more]
Unread 16-02-2010, 15:10
pm 2389 pm 2389 is offline
FRC #2389
pm 2389 is an unknown quantity at this point
Motor controling with labview
Can you control a motor with buttons on labview and if yes then how.
please use screen shots. Thank you.
Unread 16-02-2010, 15:43
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
Re: Motor controling with labview
See this link
http://decibel.ni.com/content/docs/DOC-3321
If you have more questions reply back.
Tell us what you want to happen when and how you press the buttons
Omar
Unread 16-02-2010, 15:48
FRC #2389
where do you find the hold on loop
Unread 16-02-2010, 15:52
Omar's Avatar
You have to make it your self.
What is it you are tring to do?
What do you need to happen when and how you press a button?
Omar
Unread 16-02-2010, 16:04
FRC #2389
when we press one buton we want it to run our wench, it only needs to run one way . we also need a program to run a motor on a arm that moves back and forth.
Unread 16-02-2010, 16:28
Omar's Avatar
While the button is pressed the motor will spin.
Release the button the motor will stop
Need a little more info about a arm that moves back and forth.
Think it through and write down the actions.
Like when I press button X the arm does A
When I release button X the arm does B
When I press button Y the arm does C
When I release button Y the arm does D
When I press both X and Y it does ?????
Once you write out the steps you should find it easier to code.
Omar
Unread 16-02-2010, 18:51
AMFof306 AMFof306 is offline
FRC #0306
AMFof306 is an unknown quantity at this point
Thanks Omar, i was reading over this and was really confused until stumbling upon this.
Stepper Motor Controling BEEKMAN Motors 2 04-12-2009 08:29
NXT SERVO CONTROLING SPEED CONTROLER mjgard Programming 5 04-11-2009 15:25
controling extension on piston m1k3 Pneumatics 16 14-01-2008 16:04
External metal jacket on the Drill motor and FP motor, WHY? archiver 2001 3 24-06-2002 04:22
Controling Pneumatics archiver 2001 14 23-06-2002 22:44
