Hundreds of more watchdog errors even wih the new update
I would have posted this onto the thread of someone who had similar problems, but found that my situation was different enough.
I have just finished installing the new Labview update, cRio image, and driver station updates. dsVersion 10.02.08.00 cRIO Image LabView - 20010_v20 I am not sure how much is related, but am also getting many errors along the lines of " ERROR <Code> 1026 occurred at Property Node in NI_FPGA_Interfaace.lvlib:NIFPGA System.lvlib:Async VI Agent.vi LabVIEW: VI Reference is invalid " and although probably less related, I am not able to get a battery voltage reading in the ds either. I have not made any changes to the vision system and can get video easily, though disabling it doesn't help either. I have not made any changes in the watchdog code for teleop either. I get the same symptoms in both teleop and autonomous modes, and the ds indicator switches between "... Enabled," "Watchdog Not Fed," and "No Robot Code." Any help would be appreciated. Thanks, |
Re: Hundreds of more watchdog errors even wih the new update
Did you rename your top level VI?
Did you run Start Communication in more than one place? What exactly did you changes that a caused you to start getting the errors about the invalid VI reference? |
We have the same probelm, even though we are using java
I would suggest to both teams that you try loading the default framework (only changing the motor references to be appropriate). I haven't seen those errors before, so I suspect it's something you've done to your code.
I've even tried running "virgin" code and get this error, its prolly a bug in the cRio firmware
If you reimage the cRIO and run the unmodified new project you still get these errors?
#7
ya, we tried that, itll be bad if it isnt fixed before competition #ni
#8
We haven't been able to reproduce it... so we need you to provide more details as to what could be causing you to have this problem but not us or anyone else.
Thanks, -Joe |
#9
What does your hardware setup look like right now? Are the cRIO modules in their correct positions?
#10
it happens randomly, also being unpredictable.
#12
They were user watchdog errors I was getting, I didn't rename any of the default vi's or call Start Communication myself, I re-imaged my cRIO and the virgin code worked fine, so I am slowly reincorporating my code into that, and hopefully will find the breaking point soon.
| Hundreds of "Watchdog Expiration: System X" Errors | lollypop2020 | Programming | 21 | 18-02-2010 09:52 |
| Still more watchdog trouble | ringo115 | NI LabVIEW | 3 | 16-02-2009 10:44 |
| Even More New vex parts!! | Chuck Glick | VEX | 6 | 04-12-2007 23:18 |
| Even even more Segway stuff. | FotoPlasma | Dean Kamen's Inventions | 1 | 15-08-2003 22:15 |
| FIRST looses even more ground in the war for TV fame?? | archiver | 2000 | 4 | 23-06-2002 23:53 |
