Go to Post EVERYTHING in life is politics. - Amanda Morrison [more]
Unread 17-02-2010, 13:03
enrique's Avatar
enrique enrique is offline
FRC #1251 (Tech Tigers)
Team Role: Electrical
enrique will become famous soon enough
Send a message via Yahoo to enrique
ADXL345 Programming
Anyone have code samples of the ADXL345 being used connected to the gpio?
Also, looking for a code sample or help in using the bump sensor I1 I2.
The FRC documentation seems to suggests you connect via J4 (SPI) to the side car GPIO, but the code samples I find are for (I2C) via J2. The part I need most at the moment is the bump sensor.
Unread 17-02-2010, 13:17
Zme Zme is offline
FRC #2619
Zme is on a distinguished road
Re: ADXL345 Programming
we used i2c for it, seems to work out ok, a bit of noise in it but not too much. my question is this, is there an advantage to doing it through the GPIO?
Unread 18-02-2010, 15:56
enrique's Avatar
I do not believe there is any benefit to using the GPIO, but since the FRC Sensor manual Rev A suggests you hook into the GPIOs, then I was trying to do it that way. I guess I can rewire to use the SPI. However, the "bump sensor" on it is also suggested to plug into the GPIO. So I figure plug it all in the GPIO, but then the code I see for it is SPI. I'll go ahead and use SPI, but still need to know if there is some code for using the "bump sensor". If not I guess I can reverse engineer it and use the analog.com specs if no one has anything.
ADXL345 SPI Accelerometer set/get Refnum Jon236 NI LabVIEW 3 16-02-2010 10:20
ADXL345 using I2C tdidi C/C++ 1 29-01-2010 21:02
hook up ADXL345 to cypress breadboard at driver station erichahn525 Programming 4 23-01-2010 12:22
Programming in Python and Explaination of Programming roboxking Programming 22 07-01-2008 16:08
programming motors with programming kit BorisTheBlade FIRST Tech Challenge 4 01-11-2005 19:03
