Go to Post Thou shalt becometh pinned in eliminations. - JesseK [more]
Unread 17-02-2010, 14:49
mattbutts mattbutts is offline
FRC #1741 (Red Alert)
mattbutts is an unknown quantity at this point
Potential Issue with the C++ CANJaguar Implementation
I have our Jaguars all running in CAN communication mode and the ones that are being controlled in voltage control are working great.
However, when I try to control a Jaguar in position control, I am getting garbage back from the encoder. I verified that everything was setup correctly by testing it with the BDC-COM utility. I can see the encoder perfectly there, and I can tune the controller and it works great.
We have a display for the encoder position on the driver station, and if I watch the value here it jumps around erratically (3 -> 8 -> 11 -> 65535 etc.). This makes me think it has something to do with the way the code is unpacking the data from the CAN messages, but I am not familiar enough with the messages to know that this is the case.
I guess my real question is: Has anyone else been able to get meaningful data back from a CANJaguar, and if so, did you have to do anything special? I really need to be able to get the position reliably.
Thanks,
Matt
Unread 19-02-2010, 09:09
Re: Potential Issue with the C++ CANJaguar Implementation
We were able to get it working. We believe that somehow the Jaguar was getting set to expect a potentiometer rather than an encoder. Not sure how though as we only had code in there for the encoder configuration.
Anyway, it works great now.
Unread 19-02-2010, 13:26
M.Rehberg's Avatar
M.Rehberg M.Rehberg is offline
AKA: Mike Rehberg
FRC #2619 (The Charge)
M.Rehberg is an unknown quantity at this point
Would it be expecting an Absolute Encoder that outputs a 0-5 V signal based on shaft position? If you are working with a position control mode, that is what I would expect Vs using a relative quadrature encoder.
Mike R.
Mike Rehberg
Team 2619
Midland, MI
Weird issue with the power distribution block X-Istence Electrical 17 08-03-2009 18:32
[FTC]: [FTC]: RobotC Template Problem (causing an FMS issue) and Potential Servo Prob PackersFan FIRST Tech Challenge 11 26-01-2009 21:25
An Issue with downloading the Master Code. Neil [Coconuts] Programming 6 07-02-2008 14:03
Issue with downloading code to the 2007 RC thefro526 Programming 3 10-02-2007 17:26
Potential Problem with "fighting over the goal" Kyle Fenton General Forum 4 17-02-2002 10:21
