Go to Post You have the right to remain silent. Anything you say can AND WILL be held against you (AND YOUR TEAM) in the court of public opinion. So choose what you do wisely. - Koko Ed [more]
Unread 17-02-2010, 23:07
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Drive System Sensitivity
I have read over the API and I have tried changing the sensitivity but I do not feel a significant slow down. The default is 0.5 and ridiculously small and big numbers, which does not significantly slow or speed up the robot's drive system. Neither does 0.0-1.0 Has anyone figured out how the double is used in the equation exactly?
Unread 18-02-2010, 10:52
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Re: Drive System Sensitivity
Unfortunately, the Sensitivity input is only used by the Ratio Curve version of the Arcade Drive VI. Sorry about that - I have made a note to improve it for next year.
That said, you can implement your own sensitivity. All you would need to do is scale the value that goes from your joystick to your chosen motor drive VI.
Tank Drive 'sensitivity' fishLlama NI LabVIEW 5 19-02-2010 21:44
crab drive vs. mecanum drive system superbotman Technical Discussion 33 06-01-2010 03:09
drive system MarcusRoth General Forum 1 23-12-2009 12:44
Drive System archiver 2000 6 23-06-2002 22:57
