Go to Post An Evil Overlord is only as bad as the creatures she/he rules. - MissInformation [more]
Unread 18-02-2010, 08:21
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
Using TimerTasks
Is it a good idea to create TimerTasks to take care of updating certain portions of the robot, such as the drive train or the ball handling system? For instance, if there is something that needs to be called regularly (like setting the Jaguars for motors or checking limit switches, etc.) just set a TimerTask to call it at a 20ms period so that we don't have to worry about updating.
I have them working, but I'm wondering if there are any disadvantages that I'm missing, and also hoping to help anyone who wants to try.
Unread 18-02-2010, 22:31
Lord_Jeremy's Avatar
Lord_Jeremy Lord_Jeremy is offline
Lord_Jeremy the Procrastinator
AKA: Jeremy Agostino
FRC #1546 (Chaos Inc.)
Team Role: Electrical
Lord_Jeremy is an unknown quantity at this point
Send a message via ICQ to Lord_Jeremy Send a message via AIM to Lord_Jeremy Send a message via MSN to Lord_Jeremy Send a message via Yahoo to Lord_Jeremy
Re: Using TimerTasks
It sounds to me like you're redoing what IterativeRobot does. Maybe I missed something but you're saying you want certain things to only happen periodically? I would just use IterativeRobot and change the update period or use counters to call your functions every X cycles, since the teleopPeriodic frequency is known.
Compiling...
Compiling...
Unread 18-02-2010, 23:16
FRC #0107
Well, we're already doing that, but I set up a TimerTask because it's just cleaner, because you don't need to make sure your update functions are at the end of your iterative loop or whatever. Are there any downsides to using a TimerTask?
Unread 19-02-2010, 00:19
Eh, I don't know of any, but you should probably hold out for someone with more know-how...
Compiling...
Compiling...
Unread 19-02-2010, 08:16
Jared Russell's Avatar
Taking a year (mostly) off
We use TimerTasks extensively in our code this year. Every mechanism that has any "background" tasks like filters or PID controllers gets one. In my opinion it helps to keep your robot's "main loop" uncluttered.
Unread 20-02-2010, 11:04
FRC #0107
Thanks for the reassurance.
Here's another question... If I use Timer.delay() from the WPILibJ in a TimerTask, does that still pause ALL of your code? I wouldn't think so, because it only sleeps the current thread (as I understand it... I'm not sure).
Here's the delay() function in the Timer Class:
    public static void delay(final double seconds) {
        try {
            Thread.sleep((long) (seconds * 1e3));
        } catch (final InterruptedException e) {
Thanks!
Unread 22-02-2010, 17:03
ericarseneau ericarseneau is offline
ericarseneau is an unknown quantity at this point
It only pauses the calling Thread. Although you do need to keep in mind that this type of delay does not mean that something will occurr every seconds of time. It means that the something will occur AFTER seconds of time has gone by. This means that if your code runs for a long time, you may not get the period you might be expecting.
Unread 23-02-2010, 10:39
JasonStern JasonStern is offline
FRC #1123 (AIM Robotics)
JasonStern is on a distinguished road
Originally Posted by ericarseneau View Post
... does not mean that something will occurr every seconds of time.
You can call Timer.scheduleAtFixedRate if you want something to be run at a fixed period.
Timer.schedule will run something at a fixed delay instead.
Check out the javadocs for more info: http://www.wbrobotics.com/javadoc/java/util/Timer.html
-Jason
Que será será
Using Magnets 1jbinder Rules/Strategy 6 23-01-2008 19:42
using tangent LightWaves1636 Math and Science 2 13-02-2006 08:06
Using Potentiometers arpus maximus Electrical 5 20-11-2004 16:45
Using Linux? Raven_Writer IT / Communications 41 05-07-2004 16:53
Using Flash Keys Website Design/Showcase 8 12-03-2003 18:31
