Go to Post "Recycle Rush? What's that, some sort of charity marathon?" - Chak [more]
Unread 18-02-2010, 08:29
whatabouteve whatabouteve is offline
AKA: Dean Keithly
FRC #0245 (Adambots)
whatabouteve is an unknown quantity at this point
potentiometer/ analog inputs
We are having trouble getting our potentiometer code to work.
we declare it
AnalogInput *potemtiometer;
later
potentiometer = new AnalogInput(2);
and we can't figure out the last part. We don't have anything to go off of because last year was an easy 1,2,3 robot.
Unread 18-02-2010, 09:04
Zme Zme is offline
FRC #2619
Zme is on a distinguished road
Re: potentiometer/ analog inputs
try using AnalogChannel instead of input
Unread 18-02-2010, 09:54
AKA: Dean Keithly
okay we'll try that.
Unread 18-02-2010, 15:58
AKA: Dean Keithly
attempting analog channel didn't work when we added
float anglesh = pot1.GetVoltage();
Unread 18-02-2010, 16:49
Racer26 Racer26 is offline
shouldn't it be pot1->GetVoltage();?
Unread 18-02-2010, 18:41
AKA: Dean Keithly
i'm trying to make the code right and it compiles but we'll see if i get something.
i haven't actually had a potentiometer until now.
Unread 18-02-2010, 22:40
Zme Zme is offline
FRC #2619
1075guy is right, because you declared it using a pointer you must use -> instead of .
Unread 19-02-2010, 15:06
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
use pot1->GetValue() for a 0-1023 range value, pot1->GetVoltage() for 0.0-5.0 range. Try both and see which one you like better
Watchdog.Kill();
Unread 20-02-2010, 21:40
AKA: Dean Keithly
i try printing the values to the screen and i get really big values sometimes. Why would this be? is it because i might run the loops they are in too quuickly. i set them to .02 seconds and i think its doing better.
I actually disabled the watchdog for the autonomous because it won't run through long waits in the system. this worked until just now when it started giving me watchdog not fed errors that have never happened before.
Unread 21-02-2010, 00:45
Perhaps there's a digit or two left over on the screen from a previous print step? For example, if one value is 1003 and the next one is 996, it might end up on screen looking like 9963 if you aren't careful.
Unread 21-02-2010, 09:11
AKA: Dean Keithly
this could be i will try to fix this.
would printing
printf(" =angletop");
printf("%d",angletop);
would this work in the correct format assuming it prints on line 1 and the %d writes over it?
Help! Analog Inputs!! brennerator Programming 7 11-02-2007 15:48
Analog Inputs bush Programming 5 13-03-2006 17:49
Analog Inputs prob. Bharat Nain Programming 2 07-02-2004 20:48
Failing analog inputs? Phasmatis568 Control System 5 22-01-2004 13:28
Analog Inputs 316_programer Technical Discussion 2 05-02-2002 05:53
