Go to Post The energy source of the future is brain power. - Michael R. Lee [more]
Unread 18-02-2010, 18:25
alex42 alex42 is offline
FRC #1072
alex42 is an unknown quantity at this point
Deployment Communications Fail
When we try to deploy code to the cRIO, it works sometimes but most of the time it loses connection and fails. Specifically, it essentially always loses connection while Deploying 2010 Game Robot Project.lvproj, and usually doesn't pick it up again. It never loses communication at any other time though. This problem showed up suddenly yesterday (we updated our LabVIEW and DS the day before yesterday, so it doesn't seem to be that). When it showed up, we were testing archived versions of the code from around a week ago (we were trying to figure out what caused this problem to show up: http://www.chiefdelphi.com/forums/sh...01#post923301), and we we checked the most recent version again the problem persisted.
Unread 18-02-2010, 20:12
Re: Deployment Communications Fail
If this is simply the dialog that says it may have lost the connection and has a cancel button, you may just want to wait a bit longer. If you cancel, you cancel the download. If you wait, it will either resolve and close the dialog, or it will fail out after ten to fifteen seconds and put up a different dialog.
My understanding is the first dialog is simply indicating that some comms are timing out, possibly due to a big download.
Greg McKaskle
Unread 18-02-2010, 20:34
FRC #1072
I do wait. Usually it just sits there for several minutes. At that point I conclude it's not going to move on. Sometimes I wait and it resumes and then it all works fine.
Unread 19-02-2010, 07:26
When it doesn't resume, you might try a simple cRIO reset, then try again. I'm looking for a process that works that doesn't involve a 20 min formatting for a bunch of flash. It is very unlikely that there is anything wrong with the image that it needs to be flashed.
Greg McKaskle
Unread 20-02-2010, 04:01
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
I'll add that we are having the same problem.
When we deploy, it always fails at that same point. This started occuring a day or two after we updated LabVIEW (i.e. today/yesterday (it's 12:58am.))
I'm waiting right now for it to continue, but it doesn't look like it will.
Thank you for any help.
Unread 20-02-2010, 06:56
jonboy jonboy is offline
Engineer/Mentor
FRC #0885 (The Green Team)
jonboy is an unknown quantity at this point
Sounds like we are having the same problem. Don't remember exactly but it gets to the project line and posts the waiting message loss connect with the CRIO. Ping works great. If I try to deploy again it says access denied. After about 30 minutes of screwing around with restarting the CRIO and the DS it eventually deploys successfully and then subsequent deploys work well if nothing is shutoff. Haven't found the magic recipe to reliability get it to work. I hope there is a fix to this communication bug soon!
... jon
Unread 21-02-2010, 02:06
Rideout Rideout is offline
FRC #0034
Rideout is an unknown quantity at this point
We had the same problem today on two different cRIOs. A post on NI comunities susggested to try setting the no app on startup dip switch to halt an active program. Will try tomorrow an post results
Team 34 Rockets
Unread 22-02-2010, 07:31
Engineer/Mentor
We followed the advice from nathand in the NI.COM FIRST discussions. http://decibel.ni.com/content/thread/6231?tstart=0 We set the CRIO dip switch to "No APP". We were then able to deploy our code from our Laptop wirelessly on the first attempt. It's working great! TNX agn to nathand.
... jon
cRio Communications Fail Aaron V FRC Control System 1 15-02-2010 00:12
Deployment Time SpaceOsc NI LabVIEW 1 06-02-2009 13:18
Wireless Deployment / Ipconfig p00rleno NI LabVIEW 3 31-01-2009 12:28
Ramp deployment a hazard? marc Rules/Strategy 7 11-02-2007 10:54
