Go to Post Valentine's day, who has time for Valentine's day?????? I have code to write!! - paulcd2000 [more]
Unread 19-02-2010, 16:12
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
Rotational Encoders?
Will the normal encoder class read the rotational encoder the same as the ones on the gear boxs?
Or is there a specific way to use the rotational encoders? And if there is, how so?
Examples would be nice!
Unread 19-02-2010, 16:27
oddjob oddjob is offline
oddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to behold
Re: Rotational Encoders?
Yes.
  INT32 count_encoder_1;
  Encoder *m_encoder_1;
    m_encoder_1 = new Encoder(1, 2, false, Encoder::k4X);
    m_encoder_1->Reset();
    m_encoder_1->Start();
    count_encoder_1 = m_encoder_1->Get();
Unread 19-02-2010, 16:31
DjMaddius's Avatar
AKA: Matt Smith
Alright thanks
Unread 20-02-2010, 22:01
Are you talking about the magnetic angular position sensors? How to use them depends mostly on what you want to use them for. It would probably be easiest to read the analog sine/cosine values, which is appropriate for measuring something like the angle of an arm joint.
pic: Saving weight (and rotational mass) M4 Sherman Extra Discussion 11 09-08-2006 00:20
Encoders Ctx32 Programming 8 13-05-2006 23:54
3 Encoders stephenthe1 Programming 5 17-11-2005 19:21
multi rotational potentiometers jdawson Electrical 8 27-01-2003 08:12
