Go to Post Sometimes I think all the Game Hint does to us is make us terrible listeners. - Chris is me [more]
Unread 20-02-2010, 10:46
dan_h dan_h is offline
EE Grad Student
AKA: Dan Huizenga
#0518
dan_h is an unknown quantity at this point
Robot Signal Light long on / short off?
I'm in our shop today, once again helping to debug a currently unkown problem with our robot. Our RSL is flashing a long/short pattern when enabled in teleoperated. I found a list of RSL patterns here:
http://decibel.ni.com/content/docs/DOC-3120
However, I can't find anything that indicates what long on / short off means.
Anybody have an answer?
Thanks!
Team 518 Home Page
Unread 20-02-2010, 11:06
Re: Robot Signal Light long on / short off?
That post is form last year, and while mostly correct, a steady light with short off period was added to indicate tele enabled. I don't have the code in front of me, so it could be auto enabled instead. Anyway, this is an expected pattern.
Greg McKaskle
Unread 21-02-2010, 01:50
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Thanks!
I've added a comment to the page you referenced. Unfortunately I don't seem to have access to acctually edit the page and make it current.
Unread 21-02-2010, 02:12
114Klaatu0x72's Avatar
114Klaatu0x72 114Klaatu0x72 is offline
DQN
AKA: Sean
FRC #0114 (EagleStrike)
114Klaatu0x72 has a spectacular aura about114Klaatu0x72 has a spectacular aura about114Klaatu0x72 has a spectacular aura about
Send a message via AIM to 114Klaatu0x72
Did you wire the light correctly? La and Lb should be bridged, in addition to being the positive. While not explicitly stated in text, in the power distribution wiring diagram, it shows how the light should be wired.
Unread 21-02-2010, 09:28
The new blink pattern is documented in chapter 1 of the control system manual. The La/Lb jumper is required by <R59>.
Robot Signal Light smcmahon Electrical 20 08-03-2009 18:11
Robot Signal Light Magnechu Electrical 4 14-02-2009 15:17
Signal Light DustinB_3 Electrical 10 21-02-2007 13:10
Whats the Robot Signal light for? steve d Electrical 12 20-02-2007 08:29
Robot signal light 11Mort11 Regional Competitions 11 19-02-2007 10:46
