Go to Post Intent is determined by those that are doing, not those that are watching. - meaubry [more]
Unread 20-02-2010, 12:12
Jim Wagner Jim Wagner is offline
FRC #1676 (Pascack Pi-oneers)
Jim Wagner is an unknown quantity at this point
Send a message via Yahoo to Jim Wagner
Labview Build Errors
We are seeing the following build error, does anyone know how how to resolve this?
An error occurred while saving the following file:
C:\Documents and Settings\Jwagner\My Documents\LabVIEW Data\Team1676\20100220a Pele - Jim Working\Pele\Teleop.vi
Invoke Node in AB_Source_VI.lvclass:Close_Reference.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_RTEXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
<APPEND>
Method Name: <b>Save:Target Instrument</b>
Unread 20-02-2010, 18:27
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
Re: Labview Build Errors
<APPEND>
We had this exact same problem last week. Eventually the problem went away on its own (after we'd identified the source of the error by selectively deleting subVIs and attempting to build until the error went away). In our case, the error was associated with a modified (and renamed) copy of HolonomicDrive.VI we had placed in our project. At some point we attemped building with our modified copy again and it built successfully. We haven't seen the problem for over a week now (we periodically build, just to be sure).
The strange thing is we went for weeks just deploying the code to RAM with no errors; we only had problems when we performed a Build.
Good luck - this could be a tough one to fix.
Unread 22-03-2010, 12:18
ayeckley's Avatar
AKA: Alex Yeckley
FWIW, had the same problem (Error 1502) occur again yesterday. This time the supposedly offending item was "Begin.VI". The solution I found was to revert to an older copy of Begin.VI that had been successfully built in the past, build it (successfully), re-implement the exact same changes, then build it again (successfully). This is the second time this approach has worked. Solution time: 4 hours including the time spent trying to diagnose the problem. Once I gave up trying to find an actual error in the VI, the time spent to backtrack and re-implement was only about 20 minutes. This will be my preferred approach in the future, obviously.
As before, the code could be deployed w/o any errors generated or issues in function, but wouldn't successfully build. It would *supposedly* build OK (no errors were generated, at least) when the "enable debug" setting was checked under the Advanced tab in the build options, but after uploading to the cRIO it resulted in a "No Robot Code" condition. Experimentation showed that the issue was not related to file or folder permissions, nor file or folder path length.
Unread 22-03-2010, 14:55
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
We had an issue earlier this year where we could use the RUN function to execute code, but when we did a build, we would get an error. I don't remember the code, but it looked much like the one in the first post.
NI looked at the problem and found that it was caused by a known bug in LV.
We had some debug code that we were disabling by putting a case statement around it and setting the control to FALSE using a constant. Changing the case input to a control rather than a constant fixed the problem.
Labview Plugin/Build errors Brandon Holley NI LabVIEW 3 05-12-2009 11:11
Time to build cRIO LabVIEW code Terry Sherman FRC Control System 10 05-03-2009 01:10
Labview Build Unsuccessful Plepel NI LabVIEW 3 17-02-2009 14:01
Errors on LabVIEW PHSRobotics NI LabVIEW 12 11-02-2009 10:00
LabVIEW Woes: Build/Deploy time too long?! leftylink NI LabVIEW 7 27-01-2009 21:52
