Go to Post Givens do not need solutions. - Al Skierkiewicz [more]
Unread 20-02-2010, 16:36
Twisted eric's Avatar
Twisted eric Twisted eric is offline
FRC #0581
Twisted eric is an unknown quantity at this point
solenoid problems
I need help with Programming the solenoid to a the trigger button on our controller it will be on the kicker joystick.
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Watchdog;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.Jaguar;
public class Demonized extends SimpleRobot {
    private static final long TIME_DELAY = 1000; // in milliseconds
    RobotDrive drive = new RobotDrive(1, 2);
    Joystick leftStick = new Joystick(1);
    Joystick rightStick = new Joystick(2);
    Joystick kicker = new Joystick(3);
    Watchdog fenrir = Watchdog.getInstance();
    Compressor fluffy = new Compressor(1, 1);
    Joystick leftstick = new Joystick(1);
    Joystick rightstick = new Joystick(2);
    Jaguar spot = new Jaguar(4);
    Joystick pup = new Joystick(4);
    void setUpRobot() {
        fluffy.start();
        fenrir.feed();
    public void autonomous() {
        setUpRobot();
            while (true && isAutonomous() && isEnabled()) {
                for (int i = 0; i < 4; i++) {
                    fenrir.feed();
                    drive.drive(0.5, 0.0);  // drive 50% fwd 0% turn
                    fenrir.feed();
                    drive.drive(0.0, 0.5);  // drive 0% fwd 50% turn
                    fenrir.feed();
                    drive.drive(0.0, -0.5); // drive 0% fwd -50% turn
            drive.drive(0.0, 0.0); // drive 0% fwd, 0% turn
    public void operatorControl() {
        setUpRobot();
        while (true && isOperatorControl() && isEnabled()) // loop until change
            drive.tankDrive(leftStick, rightStick);
            Timer.delay(0.005);
            fenrir.feed();
           // New compressor code...
if (fluffy.getPressureSwitchValue()) {
fluffy.setRelayValue(edu.wpi.first.wpilibj. Relay.Value.kOff);
} else {
fluffy.setRelayValue(edu.wpi.first.wpilibj. Relay.Value.kOn);
    //And don't forget to turn the compressor off when exiting your operatorControl loop...
help will be much appreciated.
Unread 20-02-2010, 17:15
ygd ygd is offline
FRC #3341 (Manhattan Project)
ygd is an unknown quantity at this point
Re: solenoid problems
What's the point of this:
} else {
Also, this was our code when we were using pneumatics for our kicker:
if (System.currentTimeMillis() - lastFired >= 2000) {
                if (j.getTrigger() && !fired) {
                    fire();
                    fired = true;
                    lastFired = System.currentTimeMillis();
                } else if (!j.getTrigger() && fired) {
                    fired = false;
            try {
                Thread.sleep(50);
            } catch (Exception e) {
                System.out.print(e.getMessage());
                e.printStackTrace();
Where fire() launches the solenoids and fired is a boolean set to false and lastFired is a long set to 0. This code also makes sure you can only fire once every two seconds.
Unread 20-02-2010, 17:18
FRC #0581
} else {
this will i believe to turn off the compressor
(have not yet tried it yet)
also is the only import we need is
import edu.wpi.first.wpilibj.solenoid;
right
thanks.
Unread 20-02-2010, 17:25
FRC #0581
How can I implement that into my code.
Unread 20-02-2010, 22:34
KayyPii's Avatar
KayyPii KayyPii is offline
FRC #1404 (SHOCKs)
KayyPii will become famous soon enough
After you import the solenoid class, you will have to create your solenoid objects in Java. You can do this using :
Solenoid kicker = new Solenoid ( slot, channel );
then in your program, you can check the status of the trigger using an "if" selection and use the set( boolean on ); method to turn the solenoid on.
=>"That hole you drilled is a little off."
=>"Don't panic, just make it bigger and put a washer on it!"
=>Eye ball once, and cut as many times as it takes
Unread 21-02-2010, 14:14
FRC #0581
Can you please show me an example this is my first year programming in Java and I have no mentor to help.
Unread 21-02-2010, 22:08
KayyPii's Avatar
FRC #1404 (SHOCKs)
Solenoid kicker = new Solenoid ( 7, 1 ); //locate a solenoid on slot 7 of cRio and channel 1 on the solenoid breakout.
if ( pup.getButton( Joystick.ButtonType.kTrigger ) == true ) //if the switch is pressed
         kicker.set(true); //turn on the solenoid
else
         kicker.set(false); //turn off the solenoid
That is pretty much our code for our kicker with the few changes to the variable names. Also, I believe that when you initialize the solenoid to channel 1, it is the first channel on the breakout board. I think its labelled as 0. Hope this helps
Unread 20-02-2010, 17:58
nikRbokRz nikRbokRz is offline
FRC #1683
nikRbokRz is an unknown quantity at this point
} else {
right
thanks.
First of all, instead of doing "edu.wpi.first.wpilibj.Relay.value.kOn", isn't it much easier to just to "Relay.value.kOn"?
From what my team assumed, the compressor automatically turns on/off, depending on the pressure switch. We initially couldn't get it to work, but it turned out to just be a bad spike. So I'm not really sure if you need to be turning it on/off.
As for the solenoid, yes all you need to import is
import edu.wpi.first.spilibj.Solenoid;
Depending on how you've connected your solenoid(s), you will have to set them true or false to get it to work as you wish.
Hope that helped.
Solenoid actuation problems Alexandstein Pneumatics 4 17-02-2010 21:39
Solenoid not firing off Solenoid Breakout spooncwru Pneumatics 2 30-01-2010 17:46
single solenoid seanl Pneumatics 4 18-02-2007 02:32
Programming a Solenoid Brigander Pneumatics 4 17-02-2007 14:06
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
