pic: (1860) Brazilian bot exported!!!!
Re: pic: (1860) Brazilian bot exported!!!!
Ummm....fyi you cant use globe motors this year, as they were not included in this year KOP
<R52> Motors specifically permitted on 2010 FRC ROBOTS include: A. All motors, actuators, and servos listed in the 2010 KOP, B. An unlimited number of COTS servos with a maximum output torque of 55 oz-in and maximum rotational speed of 100 rpm at 6 Vdc (e.g. HITEC model HS-322HD or HS-325HB servos, as provided in the KOP), C. An unlimited number of FIRST Tech Challenge (FTC) servos (HITEC HS-475HB servos), D. One, two, or three additional 2˝” CIM motors (part #FR801-001 and/or M4-R0062-12) in addition to those provided in the KOP. This means that up to five, and no more, 2˝” CIM motors can be used on the ROBOT. E. Identical one-to-one SPARE PARTS for motors, actuators, and servos provided in the 2010 KOP that may have failed or become damaged. |
Luckily, the Globe Motor was used to actuate the Axis camera, which could be exchanged for a set of servos put on an IFI mount or something.
But yeah, no Globes. Since people caught it early, you can arrive at NJ prepared to fix it. ![]() |
I also hate to be a bearer of bad news, but the gear box you are using for your kicker isn't legal as well. IFI no longer sells those gearboxes and therefore it isn't qualified to be a COTS item. Andymark Single Speed or Toughboxes have the same output speed and are legal.
Ignore my post if that is a custom gearbox built by your team, but from this picture it appears to be the old IFI box. Good Luck in Jersey! |
The Globe Motor won't be a problem, but the kicker gearbox let me worried! |
There is an alternative to the IFI gearbox. It happens to be the direct design ancestor of the AndyMark Toughbox, which is COTS. I believe they use similar gearing. So, you get an unmodified AM Toughbox from your shop, or get one from AM (send it to a local team, if you get their permission), and use that. It should work about the same as the IFI gearbox. It may even be a little lighter.
#7
If you guys need a toughbox shipped locally let me know.
#8
Actually, all you need are the drawings for the IFI box, such that any team could manufacture one. I believe this is a slight change in the rules this year, and some people may have missed it.
Darn... I can't find the drawings for the IFI transmission. I know they were published as part of the Virtual KoP, because I have a render that my students did in 2004 showing an IFI tranny on the robot... but I don't know if we have the CAD file anywhere, and... more to the point... I can't find where to direct you to so that you can show that the drawings are "openly available". Perhaps someone else can....? If the drawings are openly available, that should qualify your IFI gearbox as competition legal. Congratulations on getting your robot done, it looks great. I know its an extra effort shipping to and from Canada, so I have an extra respect for teams overseas. Hope this helps... Jason Last edited by dtengineering : 21-02-2010 at 01:30. |
| pic: From Brazil to L.A - #1860 Cephatron!!! | sloteera | Extra Discussion | 7 | 17-03-2009 22:55 |
| pic: Team #1860 - Removable Elevtronic Board [2] | sloteera | Extra Discussion | 5 | 11-02-2009 12:53 |
| pic: Team #1860 - Removable Electronic Board [1] | sloteera | Extra Discussion | 2 | 08-02-2009 18:25 |
| pic: Brazilian Team 1860 - 3D Electronic Board | Bruno Inácio | Extra Discussion | 6 | 02-02-2009 08:13 |
| pic: team 1860 | willianst8 | Extra Discussion | 1 | 06-04-2008 22:37 |
