Go to Post Yes, machining a dog profile into a steel sprocket on a manual mill was an experience filled with pain and regret. - Joe G. [more]
Unread 21-02-2010, 20:38
NoahLitle NoahLitle is offline
FRC #3089
NoahLitle is an unknown quantity at this point
cRIO-sidecar communication
We are having problems communicating between the cRIO and sidecar, it was working before but now it isn't.
The signal light isn't lighting and the Jaguars aren't responding to the sidecar either.
Team 3089
Unread 21-02-2010, 21:04
Re: cRIO-sidecar communication
Noah,
It sounds like the power supply wiring may have a problem. Did a wire pull out of the connector? Did someone remove the circuit breaker?
Is it possible that you are not communicating with the robot?
digital sidecar J1 pinouts (cRIO connection) stevethetinker Programming 0 09-02-2010 21:34
Changing Crio Digital Sidecar input slot from slot 4 to 5 Trevor_Decker Java 9 28-01-2010 12:29
Netbeans 6.8 Ftp to cRIO communication issue mark.amber Java 4 20-01-2010 17:10
Sidecar Debug NinjaSpawn94 NI LabVIEW 6 07-02-2009 10:48
Digital Sidecar Resistor NinJA999 Electrical 5 30-01-2009 19:53
